HOW TO PATCH pic18_usb.h TO WORK WITH PIC18F4553s
Bill_Smith
PostPosted: Wed Oct 29, 2008 3:34 pm     Reply with quote
Does anyone know what to patch in the pic18_usb.h driver to allow it to compile on the PIC18F4553? The onboard USB module should be pretty much the same as the PIC18F4550.
PostPosted: Wed Oct 29, 2008 4:48 pm     Reply with quote
Yes, this should be the case according to the datasheet.
You can include the respective device name in the lines before
#define __USB_4550__
Bill_Smith
PATCH TO ALLOW PIC18F4553 TO WORK WITH CCS
PostPosted: Thu Oct 30, 2008 5:09 am     Reply with quote
Vielen Dank fuer die helfe Fvm!
Here are the changes to the file. Just cut and replace before line 424 in the pic18_usb.h file. I placed comments at each modification.
////                          pic18_usb.c                            ////
//// Hardware layer for CCS's USB library.  This hardware layer      ////
//// supports the USB peripheral on the PIC18 family chips.  Current ////
//// supported families are:                                         ////
////     PIC18F2455/2550/4455/4550/4553                              ////
////     PIC18F2450/4450                                             ////
////     PIC18F65J50/66J50/66J55/67J50/85J50/86J50/86J55/87J50       ////
//// This file is part of CCS's PIC USB driver code, which includes: ////
////   usb_desc_*.h - an example set of config and device descriptor ////
////   usb.c - USB token and request handler code                    ////
////   usb.h - definitions, prototypes and global variables          ////
//// The following examples are provided by CCS:                     ////
////   ex_usb_mouse.c - A HID Mouse.                                 ////
////   ex_usb_hid.c - A custom application using HID protocol.       ////
////   ex_usb_kbmouse.c - A HID Mouse/Keyboard combo using multiple  ////
////                      interfaces.                                ////
////   ex_usb_kbmouse2.c - A HID Mouse/Keyboard combo using multiple ////
////                      HID Reports.                               ////
////   ex_usb_scope.c - A digital oscilloscope using a custom        ////
////                    protocol requiring custom Windows drivers.   ////
////   ex_usb_serial.c -                                             ////
////   ex_usb_serial2.c - Two examples of using the CDC driver for   ////
////     a virtual COM port.                                         ////
////   *********** NOTE ABOUT 18F2450/4450 LIMITATIONS **********    ////
////  Due to the limited USB RAM of this family, a limitation of     ////
////  this driver is that there are only 3 endpoints (0, 1 and 2).   ////
////  The HW actually supports more endpoints, but to simplify       ////
////  driver development this driver will only support the first 3   ////
////  so there is an easier memory block to work with.               ////
////  USB_MAX_EP0_PACKET_LENGTH will also be set to 8 regardless     ////
////  of USB speed, to save RAM.                                     ////
////   ************** NOTE ABOUT HW REQUIREMENTS ****************    ////
////  If you are not using internal pullups, you will need to put    ////
////  an internal pullup resistor on C4 or C5 depending on if you    ////
////  want to use slow speed or full speed.  This code configures    ////
////  the device to use internal pullups, see usb_init() if you      ////
////  want to change that.                                           ////
////  You need approximately 470nF cap on C3, even if you are using  ////
////  the internal 3.3V USB regulator.                               ////
////  To run at full speed, you must use the oscillator              ////
////  configuration (PLLx) to set the PLL divide to 4MHz.  You can   ////
////  configure the MCU clock to any speed (up to 48MHz) but the     ////
////  PLL must run at 4Mhz to provide the USB peripheral with a      ////
////  96MHz clock.  See the datasheet for details.                   ////
////  To run at slow speed you must configure your MCU to run at     ////
////  24Mhz.  See the datasheet for details.                         ////
////   ****************  NOTE ABOUT INTERRUPTS  ******************   ////
//// This driver uses INT_USB.  It requires INT_USB to interrupt the ////
//// PIC when an event has happened on the USB Bus.  Therfore        ////
//// this code enables interrupts.  A user modification can be made  ////
//// to poll the USB interrupt flag instead of relying on an         ////
//// interrupt.                                                      ////
////    ****************   USER FUNCTIONS  ***********************   ////
//// usb_init() - Initializes the USB stack, the USB peripheral and  ////
////              attaches the unit to the usb bus.  Enables         ////
////              interrupts.                                        ////
//// usb_init_cs() - A smaller usb_init(), does not attach unit      ////
////              to usb bus or enable interrupts.                   ////
//// usb_put_packet() - Sends one packet to the host.                ////
////                    If you need to send a message that spans     ////
////                    more than one packet then see usb_puts() in  ////
////                    usb.c                                        ////
//// usb_kbhit() - Returns true if OUT endpoint contains data from   ////
////               host.                                             ////
//// usb_rx_packet_size() - Returns the size of packet that was      ////
////               received.  usb_kbhit() must return TRUE else      ////
////               this is not valid.  Don't forget in USB there     ////
////               are 0 len packets!                                ////
//// usb_get_packet() - Gets one packet that from the host.          ////
////                    usb_kbhit() must return true before you call ////
////                    this routine or your data may not be valid.  ////
////                    Once usb_kbhit() returns true you want to    ////
////                    call this as soon as possible to get data    ////
////                    out of the endpoint buffer so the PC can     ////
////                    start sending more data, if needed.          ////
////                    This only receives one packet, if you are    ////
////                    trying to receive a multi-packet message     ////
////                    see usb_gets() in usb.c.                     ////
//// usb_detach() - De-attach USB from the system.                   ////
//// usb_attach() - Attach USB to the system.                        ////
//// usb_attached() - Returns TRUE if the device is attached to a    ////
////                  USB cable.  A macro that looks at the defined  ////
////                  connection sense pin.                          ////
//// usb_task() - Keeps track of connection sense, calling           ////
////              usb_detach() and usb_attach() when needed.         ////
//// For more documentation on these functions read the comments at  ////
//// each function.                                                  ////
//// The other functions defined in this file are for use by the     ////
//// USB code, and is not meant to be used by the user.              ////
//// Version History:                                                ////
////   10-30-08: Patched to work with PIC18F4553 (wrs)               ////
////   09-19-07: Fixed problems with 18F4450 family.                 ////
////   07-17-07: Added 18F4450,2450 support                          ////
////   07-13-07: Added 87J50 family support                          ////
////   11-01-05: usb_detach(), usb_attach() and usb_init_cs()        ////
////               changed for the better.                           ////
////   10-28-05: Added usb_rx_packet_size()                          ////
////   07-13-05: usb_put_packet() changed for 16bit packet sizes     ////
////             usb_flush_in() changed for 16bit packet sizes       ////
////             usb_get_packet() changed for 16bit packet sizes     ////
////             usb_flush_out() changed for 16bit packet sizes      ////
////             usb_set_configured() changed for 16bit packet sizes ////
////   06-30-05: usb_tbe() added                                     ////
////             The way endpoint 0 DTS is set has been changed.     ////
////   06-20-05: Initial Release                                     ////
////   05-13-05: Beta Release (Full Speed works)                     ////
////   03-21-05: Initial Alpha Release                               ////
////        (C) Copyright 1996,2005 Custom Computer Services         ////
//// This source code may only be used by licensed users of the CCS  ////
//// C compiler.  This source code may only be distributed to other  ////
//// licensed users of the CCS C compiler.  No other use,            ////
//// reproduction or distribution is permitted without written       ////
//// permission.  Derivative programs created using this software    ////
//// in object code form are not restricted in any way.              ////
#IFNDEF __USB_HARDWARE__
#DEFINE __USB_HARDWARE__
//let the USB Stack know that we are using a PIC with internal USB peripheral
#DEFINE __PIC__   1
#if ((getenv("DEVICE")=="PIC18F87J50") || (getenv("DEVICE")=="PIC18F86J55") || \
     (getenv("DEVICE")=="PIC18F86J50") || (getenv("DEVICE")=="PIC18F85J50") || \
     (getenv("DEVICE")=="PIC18F67J50") || (getenv("DEVICE")=="PIC18F66J55") || \
     (getenv("DEVICE")=="PIC18F66J50") || (getenv("DEVICE")=="PIC18F65J50"))
 #define __USB_87J50__
 #define USB_TOTAL_BUFFER_SPACE  ((int16)getenv("RAM")-0x500)
 #define USB_MAX_NUM_ENDPOINTS  16
#elif ((getenv("DEVICE")=="PIC18F2450") || (getenv("DEVICE")=="PIC18F4450"))
 #define __USB_4450__
 #if ((USB_EP3_TX_SIZE + USB_EP3_RX_SIZE + USB_EP4_TX_SIZE + USB_EP4_RX_SIZE + \
      USB_EP5_TX_SIZE + USB_EP5_RX_SIZE + USB_EP6_TX_SIZE + USB_EP6_RX_SIZE + \
      USB_EP7_TX_SIZE + USB_EP7_RX_SIZE + USB_EP8_TX_SIZE + USB_EP8_RX_SIZE + \
      USB_EP9_TX_SIZE + USB_EP9_RX_SIZE + USB_EP10_TX_SIZE + USB_EP10_RX_SIZE + \
      USB_EP11_TX_SIZE + USB_EP11_RX_SIZE + USB_EP12_TX_SIZE +USB_EP12_RX_SIZE + \
      USB_EP13_TX_SIZE + USB_EP13_RX_SIZE + USB_EP14_TX_SIZE + USB_EP14_RX_SIZE + \
      USB_EP15_TX_SIZE + USB_EP15_RX_SIZE) > 0)
   #error This driver only supports endpoints 0, 1 and 2 for this chip.
 #define USB_MAX_NUM_ENDPOINTS  3
 #define USB_TOTAL_BUFFER_SPACE  (0x100 - USB_MAX_NUM_ENDPOINTS*8)
#elif ((getenv("DEVICE")=="PIC18F2455") || (getenv("DEVICE")=="PIC18F2550") || \
       (getenv("DEVICE")=="PIC18F4455") || (getenv("DEVICE")=="PIC18F4550"))
 #define USB_TOTAL_BUFFER_SPACE  ((int16)0x300)
#elif ((getenv("DEVICE")=="PIC18F4553"))               // PIC18F4553 PATCH
 #define __USB_4553__                                             // PIC18F4553 PATCH
 #define USB_TOTAL_BUFFER_SPACE  ((int16)0x300)      // PIC18F4553 PATCH
 #define USB_MAX_NUM_ENDPOINTS  16                        // PIC18F4553 PATCH
#else
 #error Unknown PIC device, USB not supported in this library.
#ifndef USB_USE_FULL_SPEED
 #define USB_USE_FULL_SPEED   TRUE
#ifndef USB_CON_SENSE_PIN
 #define USB_CON_SENSE_PIN  0
#if defined(__USB_4450__)
   //due to limited ram, force max packet length to 8 for this chip
   #define USB_MAX_EP0_PACKET_LENGTH   8
#else
   #if USB_USE_FULL_SPEED==FALSE
      //slow speed requires 8byte max packet size for endpoint 0
      #DEFINE USB_MAX_EP0_PACKET_LENGTH   8
   #else
      //for full speed you can still use 8bytes, but 64 will be faster
      #DEFINE USB_MAX_EP0_PACKET_LENGTH   64
#INCLUDE <usb.h>
#define USB_BUFFER_NEEDED (USB_EP0_TX_SIZE+USB_EP0_RX_SIZE+USB_EP1_TX_SIZE+USB_EP1_RX_SIZE+USB_EP2_TX_SIZE+USB_EP2_RX_SIZE+USB_EP3_TX_SIZE+USB_EP3_RX_SIZE+USB_EP4_TX_SIZE+USB_EP4_RX_SIZE+USB_EP5_TX_SIZE+USB_EP5_RX_SIZE+USB_EP6_TX_SIZE+USB_EP6_RX_SIZE+USB_EP7_TX_SIZE+USB_EP7_RX_SIZE+USB_EP8_TX_SIZE+USB_EP8_RX_SIZE+USB_EP9_TX_SIZE+USB_EP9_RX_SIZE+USB_EP10_TX_SIZE+USB_EP10_RX_SIZE+USB_EP11_TX_SIZE+USB_EP11_RX_SIZE+USB_EP12_TX_SIZE+USB_EP12_RX_SIZE+USB_EP13_TX_SIZE+USB_EP13_RX_SIZE+USB_EP14_TX_SIZE+USB_EP14_RX_SIZE+USB_EP15_TX_SIZE+USB_EP15_RX_SIZE)
#if (USB_BUFFER_NEEDED > USB_TOTAL_BUFFER_SPACE)
 #error You are trying to allocate more memory for endpoints than the PIC can handle
 #reserve 0x400:0x4FF
#else
 #reserve 0x400:0x4FF+USB_BUFFER_NEEDED
#define debug_usb(a,b,c,d,e,f,g,h,i,j,k,l,m,n,o,p,q,r,s,t,u,v,w,x,y,z)
//#define debug_usb printf
//#define debug_putc putc_tbe
#define debug_display_ram(x,y)
void debug_display_ram(int8 len, int8 *ptr) {
   int8 max=16;
   debug_usb(debug_putc,"%U - ",len);
   if (max>len) {max=len;}
   while(max--) {
      debug_usb(debug_putc,"%X",*ptr);
      len--;
      ptr++;
   if (len) {debug_usb(debug_putc,"...");}
//if you are worried that the PIC is not receiving packets because a bug in the
//DATA0/DATA1 synch code, you can set this to TRUE to ignore the DTS on
//receiving.
#ifndef USB_IGNORE_RX_DTS
 #define USB_IGNORE_RX_DTS FALSE
#ifndef USB_IGNORE_TX_DTS
 #define USB_IGNORE_TX_DTS FALSE
//if you enable this it will keep a counter of the 6 possible errors the
//pic can detect.  disabling this will save you ROM, RAM and execution time.
#ifndef USB_USE_ERROR_COUNTER
   #define USB_USE_ERROR_COUNTER FALSE
#define USB_PING_PONG_MODE_OFF   0  //no ping pong
#define USB_PING_PONG_MODE_E0    1  //ping pong endpoint 0 only
#define USB_PING_PONG_MODE_ON    2  //ping pong all endpoints
//NOTE - PING PONG MODE IS NOT SUPPORTED BY CCS!
#ifndef USB_PING_PONG_MODE
   #define USB_PING_PONG_MODE USB_PING_PONG_MODE_OFF
#if USB_USE_ERROR_COUNTER
   int ERROR_COUNTER[6];
//---pic18fxx5x memory locations
#if defined(__USB_4550__) || defined(__USB_4450__) || defined(__USB_4553__)      // PIC18F4553 PATCH
   #byte UFRML   =  0xF66
   #byte UFRMH   =  0xF67
   #byte UIR     =  0xF68
   #byte UIE     =  0xF69
   #byte UEIR    =  0xF6A
   #byte UEIE    =  0xF6B
   #byte USTAT   =  0xF6C
   #byte UCON    =  0xF6D
   #byte UADDR   =  0xF6E
   #byte UCFG    =  0xF6F
   #define  UEP0_LOC 0xF70
#else
   #byte UFRML   =  0xF60
   #byte UFRMH   =  0xF61
   #byte UIR     =  0xF62
   #byte UIE     =  0xF5C
   #byte UEIR    =  0xF63
   #byte UEIE    =  0xF5D
   #byte USTAT   =  0xF64
   #byte UCON    =  0xF65
   #byte UADDR   =  0xF5E
   #byte UCFG    =  0xF5F
   #define  UEP0_LOC 0xF4C
#byte UEP0    =  UEP0_LOC
 //#define USB_BUFFER (0x400 + (USB_MAX_NUM_ENDPOINTS*8)) //compiler doesnt support this
 #if USB_MAX_NUM_ENDPOINTS==3
  #define USB_BUFFER 0x418   //if you have an old compiler you will need to use this
 #else
  #error Define USB_BUFFER for the number of endpoints you have (0x400 + NUM*0x08)
#else
 #define USB_BUFFER 0x500
#byte BD0STAT  =  0x400
#byte BD0CNT  =  0x401
#byte BD0ADRL  =  0x402
#byte BD0ADRJ  =  0x403
#define BD0STAT_LOC 0x400
#define BD0CNT_LOC  0x401
#define BD0ADRL_LOC 0x402
#define BD0ADRH_LOC 0x403
#define UEP(x) *(UEP0_LOC+x)
#BIT UIR_SOF = UIR.6
#BIT UIR_STALL = UIR.5
#BIT UIR_IDLE = UIR.4
#BIT UIR_TRN = UIR.3
#BIT UIR_ACTV = UIR.2
#BIT UIR_UERR = UIR.1
#BIT UIR_URST = UIR.0
#BIT UIE_SOF = UIE.6
#BIT UIE_STALL = UIE.5
#BIT UIE_IDLE = UIE.4
#BIT UIE_TRN = UIE.3
#BIT UIE_ACTV = UIE.2
#BIT UIE_UERR = UIE.1
#BIT UIE_URST = UIE.0
#bit UCON_PBRST=UCON.6
#bit UCON_SE0=UCON.5
#bit UCON_PKTDIS=UCON.4
#bit UCON_USBEN=UCON.3
#bit UCON_RESUME=UCON.2
#bit UCON_SUSPND=UCON.1
#if (USB_PING_PONG_MODE==USB_PING_PONG_MODE_OFF)
 #define EP_BDxST_O(x)    *(BD0STAT_LOC + x*8)
 #define EP_BDxCNT_O(x)    *(BD0CNT_LOC + x*8)
 #define EP_BDxADR_O(x)   *(int16 *)(BD0ADRL_LOC + x*8)
 #define EP_BDxST_I(x)    *(BD0STAT_LOC + 4 + x*8)
 #define EP_BDxCNT_I(x)    *(BD0CNT_LOC + 4 + x*8)
 #define EP_BDxADR_I(x)   *(int16 *)(BD0ADRL_LOC + 4 + x*8)
#else
#error Right now this driver only supports no ping pong
//See UEPn (0xF70-0xF7F)
#define ENDPT_DISABLED   0x00   //endpoint not used
#define ENDPT_IN_ONLY   0x02    //endpoint supports IN transactions only
#define ENDPT_OUT_ONLY   0x04    //endpoint supports OUT transactions only
#define ENDPT_CONTROL   0x06    //Supports IN, OUT and CONTROL transactions - Only use with EP0
#define ENDPT_NON_CONTROL 0x0E  //Supports both IN and OUT transactions
//Define the states that the USB interface can be in
enum {USB_STATE_DETACHED=0, USB_STATE_ATTACHED=1, USB_STATE_POWERED=2, USB_STATE_DEFAULT=3,
    USB_STATE_ADDRESS=4, USB_STATE_CONFIGURED=5} usb_state=0;
//--BDendST has their PIDs upshifed 2
#define USB_PIC_PID_IN       0x24  //device to host transactions
#define USB_PIC_PID_OUT      0x04  //host to device transactions
#define USB_PIC_PID_SETUP    0x34  //host to device setup transaction
#define USTAT_IN_E0        4
#define USTAT_OUT_SETUP_E0 0
#define __USB_UIF_RESET    0x01
#define __USB_UIF_ERROR    0x02
#define __USB_UIF_ACTIVE   0x04
#define __USB_UIF_TOKEN    0x08
#define __USB_UIF_IDLE     0x10
#define __USB_UIF_STALL    0x20
#define __USB_UIF_SOF      0x40
 #define STANDARD_INTS 0x3F
#else
 #define STANDARD_INTS 0x3D
#define __USB_UCFG_UTEYE   0x80
#if defined(__USB_4550__) || defined(__USB_4553__)      // PIC18F4553 PATCH
 #define __USB_UCFG_UOEMON  0x40
#define __USB_UCFG_UPUEN   0x10
#define __USB_UCFG_UTRDIS  0x08
#define __USB_UCFG_FSEN    0x04
   #define __UCFG_VAL_ENABLED__ (__USB_UCFG_UPUEN | __USB_UCFG_FSEN | USB_PING_PONG_MODE)
#else
   #define __UCFG_VAL_ENABLED__ (__USB_UCFG_UPUEN | USB_PING_PONG_MODE);
#define __UCFG_VAL_DISABLED__ 0x08
char usb_ep0_rx_buffer[USB_MAX_EP0_PACKET_LENGTH];
#locate usb_ep0_rx_buffer=USB_BUFFER
char usb_ep0_tx_buffer[USB_MAX_EP0_PACKET_LENGTH];
#locate usb_ep0_tx_buffer=USB_BUFFER+USB_MAX_EP0_PACKET_LENGTH
char usb_data_buffer[USB_TOTAL_BUFFER_SPACE-USB_MAX_EP0_PACKET_LENGTH-USB_MAX_EP0_PACKET_LENGTH];
#locate usb_data_buffer=USB_BUFFER+USB_MAX_EP0_PACKET_LENGTH+USB_MAX_EP0_PACKET_LENGTH
int8 __setup_0_tx_size;
Best Regards to all,
Bill
