I am attempting to use the command-line compiler (PCM) to implement a compile-then-link script. I've added the +EXPORT option, but I cannot generate a .o file. The .err file contains no errors.
I've looked at the provided mcu.zip example, but it hasn't helped much and I can't get it to build.
Any ideas? Thanks...
Posted: Wed Oct 15, 2008 10:00 pm
I am attempting to use the command-line compiler (PCM).
