Linking Compilation Units
jheddings
PostPosted: Wed Oct 15, 2008 8:53 pm     Reply with quote
I am attempting to use the command-line compiler (PCM) to implement a compile-then-link script. I've added the +EXPORT option, but I cannot generate a .o file. The .err file contains no errors.
I've looked at the provided mcu.zip example, but it hasn't helped much and I can't get it to build.
Any ideas? Thanks...
PostPosted: Wed Oct 15, 2008 10:00 pm     Reply with quote
I am attempting to use the command-line compiler (PCM).
The command line compiler doesn't support that option:
http://www.ccsinfo.com/forum/viewtopic.php?t=26954&start=10
jheddings
PostPosted: Wed Oct 15, 2008 11:20 pm     Reply with quote
Bummer... Thanks for the link. Guess we'll have to decide if the full IDE is the way to go.
