Determine ROM Usage per Function
PostPosted: Mon Oct 13, 2008 10:40 pm     Reply with quote
Hello-
Is it possible to determine the code usage per function when compiling? I'm surprised by my app's large ROM footprint, so I was hoping to track down the heavy users and try to trim them down a bit.
Thanks...
crystal_lattice
PostPosted: Tue Oct 14, 2008 12:08 am     Reply with quote
If i'm not mistaken you could look under the statistics tab/file and this should give you a break down of the ROM/RAM usage.
jheddings
PostPosted: Wed Oct 15, 2008 8:44 pm     Reply with quote
I am unable to generate the .STA file. I am using the command line compiler (version 4.066) and the +A option does not appear to do anything.
Any ideas?
PostPosted: Wed Oct 15, 2008 10:03 pm     Reply with quote
I am unable to generate the .STA file. I am using the command line compiler.
The command line compiler doesn't support that option:
http://www.ccsinfo.com/forum/viewtopic.php?t=25150&start=13
