Is it possible to determine the code usage per function when compiling? I'm surprised by my app's large ROM footprint, so I was hoping to track down the heavy users and try to trim them down a bit.
Thanks...
crystal_lattice
Posted: Tue Oct 14, 2008 12:08 am
If i'm not mistaken you could look under the statistics tab/file and this should give you a break down of the ROM/RAM usage.
jheddings
Posted: Wed Oct 15, 2008 8:44 pm
I am unable to generate the .STA file. I am using the command line compiler (version 4.066) and the +A option does not appear to do anything.
Any ideas?
Posted: Wed Oct 15, 2008 10:03 pm
I am unable to generate the .STA file. I am using the command line compiler.
