PCD mixes up work registers
FvM
PostPosted: Tue Sep 30, 2008 6:06 am     Reply with quote
in the below code detail, PCD is returning 2*addr rather than the required expression in the first case and the correct expression in the second case.
   switch (valid_address(addr)) {
       case 1:
          return ((int16*)(&Monitor_sect)+addr-ADDR_MONITOR);
021C0:  MOV     #866,W5
021C2:  MOV     1550,W4
021C4:  MUL.UU  W4,#2,W0
021C6:  ADD     W0,W5,W6
021C8:  MOV     W0,0  ; should use W6 instead !!
021CA:  BRA     2210
       case 2:
          return ((int16*)(&TTU_unreg_sect)+addr-ADDR_TTU_UNREG);
021CC:  MOV     #91A,W5
021CE:  MOV     1550,W4
021D0:  MUL.UU  W4,#2,W0
021D2:  ADD     W0,W5,W6
021D4:  MOV     #C8,W4
021D6:  SUB     W6,W4,W0
021D8:  MOV     W0,0
021DA:  BRA     2210
The different treatment is most likely caused by a zero value of the constant ADDR_MONITOR in first case.
Regards,
Frank
FvM
PostPosted: Tue Sep 30, 2008 6:16 am     Reply with quote
This way, PCD generated correct code:
       case 1:
 #if ADDR_MONITOR == 0
          return ((int16*)(&Monitor_sect)+addr);
021C0:  MOV     #866,W5
021C2:  MOV     1550,W4
021C6:  ADD     W0,W5,W0
021C8:  MOV     W0,0
021CA:  BRA     2210
 #else
 #endif
FvM
PostPosted: Tue Sep 30, 2008 1:29 pm     Reply with quote
And there are more PCD coding errors. Here with comparing an int32 variable value with a pointer referenced structure element.
                if (recvdata == pt->snr)
02600:  MOV     #0,W0      ; offset snr
02602:  ADD     15B2,W0   ; pt
02604:  MOV     #0,W4
; THIS IS THE BUG
02606:  MOV     [W0++],[W4++]   ; W0 gets overwritten
02608:  MOV     [W0++],[W4++]
0260A:  CP      1470          ; recvdata low word
0260C:  BRA     NZ,2636
0260E:  MOV     1472,W4   ; recvdata high word
02610:  CP      W4,W1
02612:  BRA     NZ,2636
