PCD mixes up work registers |
Posted: Tue Sep 30, 2008 6:06 am |
in the below code detail, PCD is returning 2*addr rather than the required expression in the first case and the correct expression in the second case.
switch (valid_address(addr)) {
case 1:
return ((int16*)(&Monitor_sect)+addr-ADDR_MONITOR);
021C0: MOV #866,W5
021C2: MOV 1550,W4
021C4: MUL.UU W4,#2,W0
021C6: ADD W0,W5,W6
021C8: MOV W0,0 ; should use W6 instead !!
021CA: BRA 2210
case 2:
return ((int16*)(&TTU_unreg_sect)+addr-ADDR_TTU_UNREG);
021CC: MOV #91A,W5
021CE: MOV 1550,W4
021D0: MUL.UU W4,#2,W0
021D2: ADD W0,W5,W6
021D4: MOV #C8,W4
021D6: SUB W6,W4,W0
021D8: MOV W0,0
021DA: BRA 2210 |
The different treatment is most likely caused by a zero value of the constant ADDR_MONITOR in first case.
Regards,
Frank |
Posted: Tue Sep 30, 2008 6:16 am |
This way, PCD generated correct code:
Code: | case 1:
#if ADDR_MONITOR == 0
return ((int16*)(&Monitor_sect)+addr);
021C0: MOV #866,W5
021C2: MOV 1550,W4
021C6: ADD W0,W5,W0
021C8: MOV W0,0
021CA: BRA 2210
#else
#endif |
Posted: Tue Sep 30, 2008 1:29 pm |
And there are more PCD coding errors. Here with comparing an int32 variable value with a pointer referenced structure element.
Code: | if (recvdata == pt->snr)
02600: MOV #0,W0 ; offset snr
02602: ADD 15B2,W0 ; pt
02604: MOV #0,W4
; THIS IS THE BUG
02606: MOV [W0++],[W4++] ; W0 gets overwritten
02608: MOV [W0++],[W4++]
0260A: CP 1470 ; recvdata low word
0260C: BRA NZ,2636
0260E: MOV 1472,W4 ; recvdata high word
02610: CP W4,W1
02612: BRA NZ,2636 |
