CCS Bootloader Problem
ntgcp_08
PostPosted: Thu Sep 18, 2008 3:44 pm     Reply with quote
I'm using processor 18LF6722
Clock is 4MHz
compiler version is PCH V4.066
I'm trying to implement a bootloader in my project but I've had little luck so far. The program just doesn't run. When I take the bootload stuff out, things function.
Here is my program stripped down as much as possible:
Main program - bootloader.c
#include "C:\Documents and Settings\kerrj\My Documents\Firmware\Bootloader\bootloader.h"
#include "C:\Documents and Settings\kerrj\My Documents\Firmware\Bootloader\bootloader_bootloader.h"
//BOOTLOADER AT START - Include Bootloader.h in your application - See sample application Ex_Bootload.c
//BOOTLOADER AT END - Always include the projectname_bootloader.h file in future versions of the project
void application(void) {
  while(TRUE){
     fprintf(DEBUG232, "Version 1.00\r\n");
   if(!input(PushButton)){
      write_eeprom(EE_ENTER_BOOTLOADER, 0xAA);
      reset_CPU();
     setup_psp(PSP_DISABLED);
     setup_spi(SPI_SS_DISABLED);
     setup_spi2(SPI_SS_DISABLED);
     setup_wdt(WDT_OFF);
     setup_timer_0(RTCC_INTERNAL|RTCC_DIV_8);          // 524mS /tick
     setup_timer_1(T1_DISABLED);
      setup_timer_4(T4_DIV_BY_16,240,13);      //50.1 mS timer
     setup_vref(FALSE);
     setup_low_volt_detect(FALSE);
     setup_oscillator(false);
     SET_TRIS_A(TRIS_A_SETTING);
     SET_TRIS_B(TRIS_B_SETTING);
     SET_TRIS_C(TRIS_C_SETTING);
     SET_TRIS_D(TRIS_D_SETTING);
     SET_TRIS_E(TRIS_E_SETTING);
     SET_TRIS_F(TRIS_F_SETTING);
     SET_TRIS_G(TRIS_G_SETTING);
     ext_int_edge( 2, H_TO_L);
     ext_int_edge( 3, H_TO_L);
      output_bit(XMIT_PWR_ON,1);  // xmitter on
      output_bit(LED1_ON,1);  // xmitter on
      delay_ms(2000);
   if(read_eeprom(EE_ENTER_BOOTLOADER) == 0xAA)
      output_bit(LED1_ON,0);  // xmitter on
      fprintf(DEBUG232, "Bootloader!!!\r\n");
      real_load_program();
      application();
bootloader.h
#include <18F6722.h>
#device adc=10
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES NOPROTECT                //Code not protected from reading
#FUSES BORV25                   //Brownout reset at 2.5V
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOCPD                    //No EE protection
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES LVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOWRT                    //Program memory not write protected
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES BBSIZ1K                  //1K words Boot Block size
#define EE_ENTER_BOOTLOADER                  357
#define TRIS_A_SETTING            0xcF
#define TRIS_B_SETTING            0x7F
#define TRIS_C_SETTING            0x90
#define TRIS_D_SETTING            0x08
#define TRIS_E_SETTING            0x18
#define TRIS_F_SETTING            0x00
#define TRIS_G_SETTING            0x24
#define PushButton         PIN_B4   // input 1
#define MESH_TX            PIN_C6   // output 0
#define MESH_RX            PIN_C7   // input 1
#define SATGSM_TX          PIN_G1   // input  0
#define SATGSM_RX          PIN_G2   // input  1
#define DEBUG_TX           PIN_E2   // output 0
#define DEBUG_RX           PIN_E3   // input 1
#define XMIT_PWR_ON        PIN_D1   // output 0
#define LED1_ON            PIN_F3   // output 0
#use rs232(baud=9600,parity=N,xmit=MESH_TX,rcv=MESH_RX,bits=8,restart_wdt,STREAM=MESH232,errors)
#use rs232(baud=9600,parity=N,xmit=SATGSM_TX,rcv=SATGSM_RX,bits=8,restart_wdt,STREAM=SATGSM232,errors)
#use rs232(baud=9600,parity=N,xmit=DEBUG_TX,rcv=DEBUG_RX,bits=8,restart_wdt,STREAM=DEBUG232, DISABLE_INTS)
//bootloader code
// APPLICATION_ISR_VECTOR - Where the compiler is going to put the ISR
#define FIRMWARE_UPGRADE_VECTOR  0          // Bootloader at Start of memory
#define MAX_UPGRADE_AREA         (0x500)    // Space required by bootloader
#define MIN_FIRMWARE_UPGRADE_MEMORY_AREA   (0x20)   // Start of bootloder code
#define MAX_FIRMWARE_UPGRADE_MEMORY_AREA   (MAX_UPGRADE_AREA-1) // End of bootloder code
#define APPLICATION_RESET_VECTOR 0x500     // New RESET Vector
#define APPLICATION_ISR_VECTOR   0x508     // New Interrupt Vector
// Re-vectored RESET vector from 0x0000 to 0x0500
// Re-vectored Interrupt vector from 0x0008 to 0x0508
#build(reset=APPLICATION_RESET_VECTOR, interrupt=APPLICATION_ISR_VECTOR)
#define LOADER_END   MAX_UPGRADE_AREA -1
#define LOADER_ADDR  MIN_FIRMWARE_UPGRADE_MEMORY_AREA
#define BUFFER_LEN_LOD 64
int  buffidx;
char buffer[BUFFER_LEN_LOD];
#define ACKLOD 0x06
#define XON    0x11
#define XOFF   0x13
#SEPARATE
unsigned int atoi_b16(char *s);
#ORG LOADER_ADDR+10, LOADER_END auto=0 default
void real_load_program (void)
   int1  do_ACKLOD, done=FALSE;
   int8  checksum, line_type;
   int16 l_addr,h_addr=0;
   int32 addr;
   #if getenv("FLASH_ERASE_SIZE")>2
      int32 next_addr;
   int8  dataidx, i, count;
   int8  data[32];
   while (!done)  // Loop until the entire program is downloaded
      buffidx = 0;  // Read into the buffer until 0x0D ('\r') is received or the buffer is full
      do {
         buffer[buffidx] = getc(SATGSM232);
      } while ( (buffer[buffidx++] != 0x0D) && (buffidx <= BUFFER_LEN_LOD) );
      putchar (XOFF, SATGSM232);  // Suspend sender
      do_ACKLOD = TRUE;
      // Only process data blocks that start with ':'
      if (buffer[0] == ':') {
         count = atoi_b16 (&buffer[1]);  // Get the number of bytes from the buffer
         // Get the lower 16 bits of address
         l_addr = make16(atoi_b16(&buffer[3]),atoi_b16(&buffer[5]));
         line_type = atoi_b16 (&buffer[7]);
         addr = make32(h_addr,l_addr);
         #if defined(__PCM__)  // PIC16 uses word addresses
            addr /= 2;
         // If the line type is 1, then data is done being sent
         if (line_type == 1) {
            done = TRUE;
         } else if ((addr < LOADER_ADDR || addr > LOADER_END) && addr < 0x2000){
         #elif defined(__PCH__)
         } else if ((addr < LOADER_ADDR || addr > LOADER_END) && addr < 0x300000){
            checksum = 0;  // Sum the bytes to find the check sum value
            for (i=1; i<(buffidx-3); i+=2)
               checksum += atoi_b16 (&buffer[i]);
            checksum = 0xFF - checksum + 1;
            if (checksum != atoi_b16 (&buffer[buffidx-3]))
               do_ACKLOD = FALSE;
            else   {
               if (line_type == 0) {
                  // Loops through all of the data and stores it in data
                  // The last 2 bytes are the check sum, hence buffidx-3
                  for (i = 9,dataidx=0; i < buffidx-3; i += 2)
                     data[dataidx++]=atoi_b16(&buffer[i]);
                  #if getenv("FLASH_ERASE_SIZE") > getenv("FLASH_WRITE_SIZE")
                        if ((addr!=next_addr)&&(addr&(getenv("FLASH_ERASE_SIZE")-1)!=0))
                     #else
                        if ((addr!=next_addr)&&(addr&(getenv("FLASH_ERASE_SIZE")/2-1)!=0))
                           erase_program_eeprom(addr);
                     next_addr = addr + 1;
                  write_program_memory(addr, data, count);
               else if (line_type == 4)
                  h_addr = make16(atoi_b16(&buffer[9]), atoi_b16(&buffer[11]));
      if (do_ACKLOD)
         putchar (ACKLOD, SATGSM232);
      putchar(XON, SATGSM232);
   write_eeprom(EE_ENTER_BOOTLOADER, 0x00);
   #ifndef _bootloader
   reset_cpu();
unsigned int atoi_b16(char *s) {  // Convert two hex characters to a int8
   unsigned int result = 0;
   int i;
   for (i=0; i<2; i++,s++)  {
      if (*s >= 'A')
         result = 16*result + (*s) - 'A' + 10;
         result = 16*result + (*s) - '0';
   return(result);
I assume the issue is how I have the RESET vector and the Interrupt vector "re-vectored". The bootload portion of the code came directly from the CCS PIC Wizard.
PostPosted: Thu Sep 18, 2008 4:12 pm     Reply with quote
#FUSES LVP
I didn't look at your code in detail, but the line above will cause problems.
Change it to NOLVP.
ntgcp_08
PostPosted: Thu Sep 18, 2008 4:19 pm     Reply with quote
Oops, somehow my #fuses changed... here is what I'm using. The program still does not function
#FUSES HS                       //External Oscillator using HS
#FUSES NOIESO                   //Internal External Switch Over mode enabled
#FUSES BORV25                   //Brownout reset at 2.0V
#FUSES PUT                      //Power Up Timer
#FUSES NODEBUG
#FUSES NOLVP                    //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOWRTC                   //configuration registers not write protected
#FUSES NOFCMEN                  //Fail-safe clock monitor enabled
#FUSES NOLPT1OSC                //Timer1 configured for low-power operation
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode enabled
#FUSES BBSIZ1K
PostPosted: Thu Sep 18, 2008 6:37 pm     Reply with quote
Your code has only one line with #org in it. There is at least a second #org required to mark the end of the bootloader section.
I don't have time to look into it now but if you compare the original generated code to what you have now you should easily spot the now missing '#org', or '#org default'.
ntgcp_08
PostPosted: Fri Sep 19, 2008 8:34 am     Reply with quote
Using the PIC Wizard the #ORG that is in bootloader_bootloader.h is the only #ORG that was added.
I went through ex_bootloader.c to see where it has #ORG statements.
My bootloader.c now looks like this:
#ORG 0x0640, 0xFFFF
  while(TRUE){
      reset_CPU();
#org 0x528, 0x63F
     setup_wdt(WDT_OFF);
     setup_vref(FALSE);
      output_bit(XMIT_PWR_ON,1);  // 5V Power On
      output_bit(LED1_ON,1);  // LED on
      delay_ms(2000);
      output_bit(LED1_ON,0);  // LED off
      application();
#ORG default
I also added an #ORG Default to the end of bootloader_bootloader.h
However, I still have no luck.
So now, I believe my memory map looks like the following... correct?
0x0000 to 0x0029 - Nothing
0x002A to 0x04FF - Bootloader
0x0500 to 0x0507 - Reset Vector
0x0508 to 0x0527 - Interrupt Service Routine
0x0528 to 0x063F - Main
0x0640 to 0xFFFF - Application
ntgcp_08
PostPosted: Fri Sep 19, 2008 10:33 am     Reply with quote
OK, I've got it working...
How I got it working??? I followed the ex_bootloader.c exacty how it was written. I didn't try using the PIC Wizard.
PostPosted: Thu Sep 25, 2008 1:28 am     Reply with quote
As a late comment:
can't be correct. The region has to hold the primary reset and interrupt handler.
