ntgcp_08
CCS Bootloader Problem |
Posted: Thu Sep 18, 2008 3:44 pm |
I'm using processor 18LF6722
Clock is 4MHz
compiler version is PCH V4.066
I'm trying to implement a bootloader in my project but I've had little luck so far. The program just doesn't run. When I take the bootload stuff out, things function.
Here is my program stripped down as much as possible:
Main program - bootloader.c
#include "C:\Documents and Settings\kerrj\My Documents\Firmware\Bootloader\bootloader.h"
#include "C:\Documents and Settings\kerrj\My Documents\Firmware\Bootloader\bootloader_bootloader.h"
//BOOTLOADER AT START - Include Bootloader.h in your application - See sample application Ex_Bootload.c
//BOOTLOADER AT END - Always include the projectname_bootloader.h file in future versions of the project
void application(void) {
while(TRUE){
fprintf(DEBUG232, "Version 1.00\r\n");
if(!input(PushButton)){
write_eeprom(EE_ENTER_BOOTLOADER, 0xAA);
reset_CPU();
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_spi2(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_8); // 524mS /tick
setup_timer_1(T1_DISABLED);
setup_timer_4(T4_DIV_BY_16,240,13); //50.1 mS timer
setup_vref(FALSE);
setup_low_volt_detect(FALSE);
setup_oscillator(false);
SET_TRIS_A(TRIS_A_SETTING);
SET_TRIS_B(TRIS_B_SETTING);
SET_TRIS_C(TRIS_C_SETTING);
SET_TRIS_D(TRIS_D_SETTING);
SET_TRIS_E(TRIS_E_SETTING);
SET_TRIS_F(TRIS_F_SETTING);
SET_TRIS_G(TRIS_G_SETTING);
ext_int_edge( 2, H_TO_L);
ext_int_edge( 3, H_TO_L);
output_bit(XMIT_PWR_ON,1); // xmitter on
output_bit(LED1_ON,1); // xmitter on
delay_ms(2000);
if(read_eeprom(EE_ENTER_BOOTLOADER) == 0xAA)
output_bit(LED1_ON,0); // xmitter on
fprintf(DEBUG232, "Bootloader!!!\r\n");
real_load_program();
application();
bootloader.h
#include <18F6722.h>
#device adc=10
#FUSES HS //High speed Osc (> 4mhz)
#FUSES BORV25 //Brownout reset at 2.5V
#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES BBSIZ1K //1K words Boot Block size
#define EE_ENTER_BOOTLOADER 357
#define TRIS_A_SETTING 0xcF
#define TRIS_B_SETTING 0x7F
#define TRIS_C_SETTING 0x90
#define TRIS_D_SETTING 0x08
#define TRIS_E_SETTING 0x18
#define TRIS_F_SETTING 0x00
#define TRIS_G_SETTING 0x24
#define PushButton PIN_B4 // input 1
#define MESH_TX PIN_C6 // output 0
#define MESH_RX PIN_C7 // input 1
#define SATGSM_TX PIN_G1 // input 0
#define SATGSM_RX PIN_G2 // input 1
#define DEBUG_TX PIN_E2 // output 0
#define DEBUG_RX PIN_E3 // input 1
#define XMIT_PWR_ON PIN_D1 // output 0
#define LED1_ON PIN_F3 // output 0
#use rs232(baud=9600,parity=N,xmit=MESH_TX,rcv=MESH_RX,bits=8,restart_wdt,STREAM=MESH232,errors)
#use rs232(baud=9600,parity=N,xmit=SATGSM_TX,rcv=SATGSM_RX,bits=8,restart_wdt,STREAM=SATGSM232,errors)
#use rs232(baud=9600,parity=N,xmit=DEBUG_TX,rcv=DEBUG_RX,bits=8,restart_wdt,STREAM=DEBUG232, DISABLE_INTS)
//bootloader code
// APPLICATION_ISR_VECTOR - Where the compiler is going to put the ISR
#define FIRMWARE_UPGRADE_VECTOR 0 // Bootloader at Start of memory
#define MAX_UPGRADE_AREA (0x500) // Space required by bootloader
#define MIN_FIRMWARE_UPGRADE_MEMORY_AREA (0x20) // Start of bootloder code
#define MAX_FIRMWARE_UPGRADE_MEMORY_AREA (MAX_UPGRADE_AREA-1) // End of bootloder code
#define APPLICATION_RESET_VECTOR 0x500 // New RESET Vector
#define APPLICATION_ISR_VECTOR 0x508 // New Interrupt Vector
// Re-vectored RESET vector from 0x0000 to 0x0500
// Re-vectored Interrupt vector from 0x0008 to 0x0508
#build(reset=APPLICATION_RESET_VECTOR, interrupt=APPLICATION_ISR_VECTOR)
#define LOADER_END MAX_UPGRADE_AREA -1
#define LOADER_ADDR MIN_FIRMWARE_UPGRADE_MEMORY_AREA
#define BUFFER_LEN_LOD 64
int buffidx;
char buffer[BUFFER_LEN_LOD];
#define ACKLOD 0x06
#define XON 0x11
#define XOFF 0x13
#SEPARATE
unsigned int atoi_b16(char *s);
#ORG LOADER_ADDR+10, LOADER_END auto=0 default
void real_load_program (void)
int1 do_ACKLOD, done=FALSE;
int8 checksum, line_type;
int16 l_addr,h_addr=0;
int32 addr;
#if getenv("FLASH_ERASE_SIZE")>2
int32 next_addr;
int8 dataidx, i, count;
int8 data[32];
while (!done) // Loop until the entire program is downloaded
buffidx = 0; // Read into the buffer until 0x0D ('\r') is received or the buffer is full
do {
buffer[buffidx] = getc(SATGSM232);
} while ( (buffer[buffidx++] != 0x0D) && (buffidx <= BUFFER_LEN_LOD) );
putchar (XOFF, SATGSM232); // Suspend sender
do_ACKLOD = TRUE;
// Only process data blocks that start with ':'
if (buffer[0] == ':') {
count = atoi_b16 (&buffer[1]); // Get the number of bytes from the buffer
// Get the lower 16 bits of address
l_addr = make16(atoi_b16(&buffer[3]),atoi_b16(&buffer[5]));
line_type = atoi_b16 (&buffer[7]);
addr = make32(h_addr,l_addr);
#if defined(__PCM__) // PIC16 uses word addresses
addr /= 2;
// If the line type is 1, then data is done being sent
if (line_type == 1) {
done = TRUE;
} else if ((addr < LOADER_ADDR || addr > LOADER_END) && addr < 0x2000){
#elif defined(__PCH__)
} else if ((addr < LOADER_ADDR || addr > LOADER_END) && addr < 0x300000){
checksum = 0; // Sum the bytes to find the check sum value
for (i=1; i<(buffidx-3); i+=2)
checksum += atoi_b16 (&buffer[i]);
checksum = 0xFF - checksum + 1;
if (checksum != atoi_b16 (&buffer[buffidx-3]))
do_ACKLOD = FALSE;
else {
if (line_type == 0) {
// Loops through all of the data and stores it in data
// The last 2 bytes are the check sum, hence buffidx-3
for (i = 9,dataidx=0; i < buffidx-3; i += 2)
data[dataidx++]=atoi_b16(&buffer[i]);
#if getenv("FLASH_ERASE_SIZE") > getenv("FLASH_WRITE_SIZE")
if ((addr!=next_addr)&&(addr&(getenv("FLASH_ERASE_SIZE")-1)!=0))
#else
if ((addr!=next_addr)&&(addr&(getenv("FLASH_ERASE_SIZE")/2-1)!=0))
erase_program_eeprom(addr);
next_addr = addr + 1;
write_program_memory(addr, data, count);
else if (line_type == 4)
h_addr = make16(atoi_b16(&buffer[9]), atoi_b16(&buffer[11]));
if (do_ACKLOD)
putchar (ACKLOD, SATGSM232);
putchar(XON, SATGSM232);
write_eeprom(EE_ENTER_BOOTLOADER, 0x00);
#ifndef _bootloader
reset_cpu();
unsigned int atoi_b16(char *s) { // Convert two hex characters to a int8
unsigned int result = 0;
int i;
for (i=0; i<2; i++,s++) {
if (*s >= 'A')
result = 16*result + (*s) - 'A' + 10;
result = 16*result + (*s) - '0';
return(result);
I assume the issue is how I have the RESET vector and the Interrupt vector "re-vectored". The bootload portion of the code came directly from the CCS PIC Wizard. |
Posted: Thu Sep 18, 2008 4:12 pm |
I didn't look at your code in detail, but the line above will cause problems.
Change it to NOLVP. |
ntgcp_08
Posted: Thu Sep 18, 2008 4:19 pm |
Oops, somehow my #fuses changed... here is what I'm using. The program still does not function
#FUSES HS //External Oscillator using HS
#FUSES NOIESO //Internal External Switch Over mode enabled
#FUSES BORV25 //Brownout reset at 2.0V
#FUSES PUT //Power Up Timer
#FUSES NODEBUG
#FUSES NOLVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOWRTC //configuration registers not write protected
#FUSES NOFCMEN //Fail-safe clock monitor enabled
#FUSES NOLPT1OSC //Timer1 configured for low-power operation
#FUSES NOXINST //Extended set extension and Indexed Addressing mode enabled
#FUSES BBSIZ1K |
Posted: Thu Sep 18, 2008 6:37 pm |
Your code has only one line with #org in it. There is at least a second #org required to mark the end of the bootloader section.
I don't have time to look into it now but if you compare the original generated code to what you have now you should easily spot the now missing '#org', or '#org default'. |
ntgcp_08
Posted: Fri Sep 19, 2008 8:34 am |
Using the PIC Wizard the #ORG that is in bootloader_bootloader.h is the only #ORG that was added.
I went through ex_bootloader.c to see where it has #ORG statements.
My bootloader.c now looks like this:
#ORG 0x0640, 0xFFFF
while(TRUE){
reset_CPU();
#org 0x528, 0x63F
setup_wdt(WDT_OFF);
setup_vref(FALSE);
output_bit(XMIT_PWR_ON,1); // 5V Power On
output_bit(LED1_ON,1); // LED on
delay_ms(2000);
output_bit(LED1_ON,0); // LED off
application();
#ORG default |
I also added an #ORG Default to the end of bootloader_bootloader.h
However, I still have no luck.
So now, I believe my memory map looks like the following... correct?
0x0000 to 0x0029 - Nothing
0x002A to 0x04FF - Bootloader
0x0500 to 0x0507 - Reset Vector
0x0508 to 0x0527 - Interrupt Service Routine
0x0528 to 0x063F - Main
0x0640 to 0xFFFF - Application |
ntgcp_08
Posted: Fri Sep 19, 2008 10:33 am |
OK, I've got it working...
How I got it working??? I followed the ex_bootloader.c exacty how it was written. I didn't try using the PIC Wizard. |
Posted: Thu Sep 25, 2008 1:28 am |
As a late comment:
Code: | 0x0000 to 0x0029 - Nothing |
can't be correct. The region has to hold the primary reset and interrupt handler. |
