RS232_ERRORS for multiple hardware uarts
soundscu
PostPosted: Sun Sep 07, 2008 9:32 am     Reply with quote
I'm using both hardware uarts on an 18F6722 for 2 separate high-speed serial streams. My application requires detection of framing errors for each port individually.
Is there a separate RS232_ERRORS variable for each uart, or do I need to write my own code to directly access RCSTA1 and RCSTA2 separately?
Thanks for your help,
Jim
PostPosted: Sun Sep 07, 2008 2:21 pm     Reply with quote
For questions like this the easiest thing to do is to write a small test program.
.................... #use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS, stream=UART1)
....................   fgetc(UART1);
00004:  BTFSS  PIR1.RC1IF
00006:  BRA    0004
00008:  MOVFF  RCSTA1,rs232_errors
0000C:  MOVFF  RCREG1,01
00010:  BTFSS  rs232_errors.1
00012:  BRA    0018
00014:  BCF    RCSTA1.CREN
00016:  BSF    RCSTA1.CREN
00018:  GOTO   0070 (RETURN)
.................... #use rs232(baud=9600, xmit=PIN_G1, rcv=PIN_G2, ERRORS, stream=UART2)
....................   fgetc(UART2);
0001C:  BTFSS  PIR3.RC2IF
0001E:  BRA    001C
00020:  MOVFF  RCSTA2,rs232_errors
00024:  MOVFF  RCREG2,01
00028:  BTFSS  rs232_errors.1
0002A:  BRA    0030
0002C:  BCF    RCSTA2.CREN
0002E:  BSF    RCSTA2.CREN
00030:  GOTO   0072 (RETURN)
What you see is that both UART1 and UART2 write the status data to the same rs232_errors variable. This implies that the status in rs232_errors will be overwritten as soon as getc is called for either of the two serial ports.
soundscu
PostPosted: Sun Sep 07, 2008 3:33 pm     Reply with quote
Agreed, and thank you for the examples.
After finding that RS232_ERRORS does not produce the desired results when both ports are receiving simultaneously, I used #BYTE to declare RCSTA1 and RCSTA2 at their hardware addresses, then tested them instead of RS232_ERRORS for the framing error flag.
This works perfectly.
Jim
