soundscu
RS232_ERRORS for multiple hardware uarts |
Posted: Sun Sep 07, 2008 9:32 am |
I'm using both hardware uarts on an 18F6722 for 2 separate high-speed serial streams. My application requires detection of framing errors for each port individually.
Is there a separate RS232_ERRORS variable for each uart, or do I need to write my own code to directly access RCSTA1 and RCSTA2 separately?
Thanks for your help,
Jim |
Posted: Sun Sep 07, 2008 2:21 pm |
For questions like this the easiest thing to do is to write a small test program. Code: | .................... #use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS, stream=UART1)
.................... fgetc(UART1);
00004: BTFSS PIR1.RC1IF
00006: BRA 0004
00008: MOVFF RCSTA1,rs232_errors
0000C: MOVFF RCREG1,01
00010: BTFSS rs232_errors.1
00012: BRA 0018
00014: BCF RCSTA1.CREN
00016: BSF RCSTA1.CREN
00018: GOTO 0070 (RETURN)
.................... #use rs232(baud=9600, xmit=PIN_G1, rcv=PIN_G2, ERRORS, stream=UART2)
.................... fgetc(UART2);
0001C: BTFSS PIR3.RC2IF
0001E: BRA 001C
00020: MOVFF RCSTA2,rs232_errors
00024: MOVFF RCREG2,01
00028: BTFSS rs232_errors.1
0002A: BRA 0030
0002C: BCF RCSTA2.CREN
0002E: BSF RCSTA2.CREN
00030: GOTO 0072 (RETURN) |
What you see is that both UART1 and UART2 write the status data to the same rs232_errors variable. This implies that the status in rs232_errors will be overwritten as soon as getc is called for either of the two serial ports. |
soundscu
Posted: Sun Sep 07, 2008 3:33 pm |
Agreed, and thank you for the examples.
After finding that RS232_ERRORS does not produce the desired results when both ports are receiving simultaneously, I used #BYTE to declare RCSTA1 and RCSTA2 at their hardware addresses, then tested them instead of RS232_ERRORS for the framing error flag.
This works perfectly.
Jim |
