constant arrays of strings
Diogo Melo
PostPosted: Mon Aug 04, 2008 11:03 pm     Reply with quote
hi, i'm trying to get this to work in v4.057:
const char source[4][25]=      {"Note                    "
               ,"Velocity                "
               ,"Aftertouch              "
               ,"Control Change          "
char bufferStr2[25];
pnt=source[currentPos]; //currentPos is a char type variable
memmove(bufferStr2,pnt,25);
and all i get in bufferStr2 is nothing good: just random "trash" from the PICs memory banks.
This actually works if i remove the const from the array.
i've also tried to follow the second example from this page but i get the same errors :http://www.ccsinfo.com/content.php?page=flexconst. and i also tried every hint i could find in this forum.
Could anyone give me a hand.
Diogo
PostPosted: Tue Aug 05, 2008 12:57 am     Reply with quote
The program shown below has the following output:
Note
Velocity
Aftertouch
Control Change
#include <18F452.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,
"Note                    ",
"Velocity                ",
"Aftertouch              ",
"Control Change          "
char *ptr;
int8 i;
for(i = 0; i < 4; i++)
    strcpy(bufferStr2, source[i]);
    printf("%s \n\r", bufferStr2);
while (1);
Diogo Melo
PostPosted: Tue Aug 05, 2008 2:19 pm     Reply with quote
Note
Velocity
Aftertouch
Control Change
#include <18F452.h>
"Note                    ",
"Velocity                ",
"Aftertouch              ",
"Control Change          "
char *ptr;
int8 i;
while (1);
thanks! apparently i shouldn't have been using the memmove() function. I started using it when i had some troubles with strcpy() when i was using an older version of the compiler.
an unrelated thing: do you know if the compiler has somekind of problem with an array of structures? i keep getting an error in the mplab watch window: Unsupported Struct. do you know anything about it?
thanks again.
diogo
PostPosted: Tue Aug 05, 2008 5:35 pm     Reply with quote
The release note for 4.076 says:
4.076 The COFF file format has been modified to allow MPLAB to read complex structures
This indicates the object file in earlier versions had some limitations...
