Diogo Melo
Joined: 04 Aug 2008 Posts: 4 Location: ISEL,Lisbon, Portugal
| constant arrays of strings |
Posted: Mon Aug 04, 2008 11:03 pm |
hi, i'm trying to get this to work in v4.057:
| Code: | const char source[4][25]= {"Note "
,"Velocity "
,"Aftertouch "
,"Control Change "
char bufferStr2[25];
pnt=source[currentPos]; //currentPos is a char type variable
memmove(bufferStr2,pnt,25);
and all i get in bufferStr2 is nothing good: just random "trash" from the PICs memory banks.
This actually works if i remove the const from the array.
i've also tried to follow the second example from this page but i get the same errors :http://www.ccsinfo.com/content.php?page=flexconst. and i also tried every hint i could find in this forum.
Could anyone give me a hand.
Diogo |
Posted: Tue Aug 05, 2008 12:57 am |
The program shown below has the following output:
| Quote: |
Note
Velocity
Aftertouch
Control Change
| Code: | #include <18F452.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,
"Note ",
"Velocity ",
"Aftertouch ",
"Control Change "
char *ptr;
int8 i;
for(i = 0; i < 4; i++)
strcpy(bufferStr2, source[i]);
printf("%s \n\r", bufferStr2);
while (1);
Diogo Melo
Posted: Tue Aug 05, 2008 2:19 pm |
| PCM programmer wrote: | The program shown below has the following output:
| Quote: |
Note
Velocity
Aftertouch
Control Change
"Note ",
"Velocity ",
"Aftertouch ",
"Control Change "
char *ptr;
int8 i;
while (1);
thanks! apparently i shouldn't have been using the memmove() function. I started using it when i had some troubles with strcpy() when i was using an older version of the compiler.
an unrelated thing: do you know if the compiler has somekind of problem with an array of structures? i keep getting an error in the mplab watch window: Unsupported Struct. do you know anything about it?
thanks again.
diogo |
Posted: Tue Aug 05, 2008 5:35 pm |
The release note for 4.076 says: | Quote: | | 4.076 The COFF file format has been modified to allow MPLAB to read complex structures | This indicates the object file in earlier versions had some limitations... |
