NIMH Charging
horizontech08
NIMH Charging
PostPosted: Thu Jul 24, 2008 6:27 pm     Reply with quote
Hi !
I am looking to put 4 AA NIMH batteries in the PCB design. I am looking
to find simple example and schematics to make slow charger with 12Vdc
input ?
I can use pic to monitor the charging !
Thanks for your help
Alain Tanguay
SherpaDoug
PostPosted: Fri Jul 25, 2008 7:40 am     Reply with quote
Look at the Maxim DS2715 or other battery charging chips from Maxim. Some of the more advanced chips have serial data readable by a PIC.
libor
PostPosted: Fri Jul 25, 2008 9:34 am     Reply with quote
Depends on the application how much intelligence I would put into the charger.
Is the battery a backup only in normally from mains operated device ?
Or is it a charge it quickly - then take it with you - device ?
Steve H
PostPosted: Mon Jul 28, 2008 10:50 am     Reply with quote
For a really simple slow charger simply use a voltage source that is 50% to 100% higher than the fully charged battery voltage (calculated at about 1.5 volts per cell) and use a dropping resistor (with the value calculated to 1.25 volts per cell) to get a charging current of about C/10. Where C is the 1 hour amp rating of the cell (or pack).
This is the way it was done in the 'old days' to get a 10-14 hour overnight charge. You can't get cheaper or simpler than a single resistor.
HTH - Steve H.
PostPosted: Mon Jul 28, 2008 11:48 am     Reply with quote
NiMH batteries require special procedures to charge them.
They require protection to prevent overcharging and they require
temperature monitoring. Read the User's Guide for the Microchip
MCP1630 NiMH charging chip:
http://ww1.microchip.com/downloads/en/DeviceDoc/51505b.pdf
Steve H
PostPosted: Tue Jul 29, 2008 8:35 am     Reply with quote
That's a nice chip - but it is a C/2 fast charger really. I thought the original question was for a slow charger - slow charging or 'Trickle' charging can be safely done unmonitored by keeping the charge current to around the C/10 rate. There are many commercial chargers / products that operate like this and work reliably.
HTH - Steve H.
