I am looking to put 4 AA NIMH batteries in the PCB design. I am looking
to find simple example and schematics to make slow charger with 12Vdc
input ?
I can use pic to monitor the charging !
Thanks for your help
Alain Tanguay
SherpaDoug
Posted: Fri Jul 25, 2008 7:40 am
Look at the Maxim DS2715 or other battery charging chips from Maxim. Some of the more advanced chips have serial data readable by a PIC. _________________ The search for better is endless. Instead simply find very good and get the job done.
libor
Posted: Fri Jul 25, 2008 9:34 am
Depends on the application how much intelligence I would put into the charger.
Is the battery a backup only in normally from mains operated device ?
Or is it a charge it quickly - then take it with you - device ?
Steve H Guest
Posted: Mon Jul 28, 2008 10:50 am
For a really simple slow charger simply use a voltage source that is 50% to 100% higher than the fully charged battery voltage (calculated at about 1.5 volts per cell) and use a dropping resistor (with the value calculated to 1.25 volts per cell) to get a charging current of about C/10. Where C is the 1 hour amp rating of the cell (or pack).
This is the way it was done in the 'old days' to get a 10-14 hour overnight charge. You can't get cheaper or simpler than a single resistor.
HTH - Steve H.
Posted: Mon Jul 28, 2008 11:48 am
NiMH batteries require special procedures to charge them.
They require protection to prevent overcharging and they require
temperature monitoring. Read the User's Guide for the Microchip
MCP1630 NiMH charging chip:
http://ww1.microchip.com/downloads/en/DeviceDoc/51505b.pdf
Steve H Guest
Posted: Tue Jul 29, 2008 8:35 am
That's a nice chip - but it is a C/2 fast charger really. I thought the original question was for a slow charger - slow charging or 'Trickle' charging can be safely done unmonitored by keeping the charge current to around the C/10 rate. There are many commercial chargers / products that operate like this and work reliably.
