Device Datasheets
The following list is where all the datasheets can be obtained for all the devices that there are source code drivers for, as located in the drivers directory. Click here to get a full list of drivers that CCS provides with the CCS C compilers.
This page last updated on December 15, 2022.
Datasheets
Driver Device Description Supplier Link
11LC160.C 11LC160 16KB UNI/O Serial EEPROM Microchip Download
23K256.C 23K256 256KB SPI Bus Low-Power Serial SRAM Microchip Download
23S17.C MCP23S17 16-bit, SPI Port Expander Microchip Download
2401.c 24LC01B 128 byte I2C EEPROM Microchip Download
2402.c 24LC02B 256 byte I2C EEPROM Microchip Download
2404.c 24LC04B 512 byte I2C EEPROM Microchip Download
2408.c 24LC08B 1KB I2C EEPROM Microchip Download
2408MM.C 24LC08B 1KB I2C EEPROM (Multi-Master) Microchip Download
241025.c 24XX1025 1024KB I2C EEPROM Microchip Download
24128.c 24LC128 16KB I2C EEPROM Microchip Download
2416.c 24LC16B 2KB I2C EEPROM Microchip Download
2421.c 24C21 1KB I2C EEPROM Atmel Download
24256.c 24LC256 32KB I2C EEPROM Microchip Download
24512.c 24LC512 512KB I2C EEPROM Microchip Download
24515.c 24FC515 512KB I2C EEPROM Microchip Download
2432.c 24LC32 4KB I2C EEPROM Microchip Download
2464.c 24LC64 8KB I2C EEPROM Microchip Download
2465.c 24C65 64KB I2C EEPROM Microchip Download
25040.c 25C040 4K SPI Bus Serial EEPROM Microchip Download
25080.c 25C080 1KB I2C EEPROM Microchip Download
25160.c 25C160x 2KB SPI EEPROM Microchip Download
25320.c 25C320 4KB SPI EEPROM Microchip Download
25640.c 25LC640x 8KB SPI EEPROM Microchip Download
25c080.c 25C080 1KB SPI EEPROM Microchip Download
68hc68r1.c CDP68HC68R1 128 byte serial EEPROM Harris/Intersil OBSOLETE
68hc68r2.c CDP68HC68R2 256 byte serial EEPROM Harris/Intersil OBSOLETE
74165.c SN74165 Input Port Expander Texas Instruments Download
74595.c SN74LS595 Input Port Expander Texas Instruments Download
9306.c 93CS06LN 16 byte SPI EEPROM Microchip OBSOLETE
9313.c 93C13N 16 byte SPI EEPROM Microchip OBSOLETE
9346.c 93AA46 128 byte SPI EEPROM Microchip Download
9356.c 93C56 256 byte SPI EEPROM Microchip Download
9356spi.c 93C56 256 byte SPI EEPROM (uses PIC's internal SPI peripheral) Microchip Download
9366.c 93C66 512 byte SPI EEPROM Microchip Download
9376.c 93AA76C 8K microwire compatible serial EEPROM Microchip Download
9386.c 93AA86C 16K microwire compatible serial EEPROM Microchip Download
9512.c 95C12N 61 byte serial EEPROM Microchip OBSOLETE
ad7705.c AD7705 16-bit serial ADC Analog Devices Download
ad7715.c AD7715 16-bit, differential input, serial ADC/TD Analog Devices Download
ad8400.c AD8400 1 to 4 channel digital potentiometer Analog Devices Download
ads8320.c ADS8320 16-bit, high speed, serial ADC Texas Instruments Download
adt7301.c ADT7301 Digital Temperature Sensor Analog Devices Download
adxl210.c ADXL210E Dual-Axis Accelerometer with Duty Cycle Analog Devices OBSOLETE
at2421.c AT24C21 128 byte serial EEPROM Atmel Download
at25256.c AT25128 or AT25256 16KB or 32KB SPI EEPROM Atmel Download
at29c1024.c AT29c1024 64Kx16 Flash Memory Atmel Download
at45db021.c AT45DB021B 2.7V DataFlash Atmel Download
can-18F4580.c PIC18Cxx8 High Performance Controller with CAN Module Microchip Download
can-18xxx8.c PIC18Fxx8 Enhanced Flash Controller with CAN Module Microchip Download
can-mcp2510.c MCP2510 CAN Controller with SPI Interface Microchip Download
can-mcp2515.c MCP2515 CAN Controller with SPI Interface Microchip Download
can-mcp2517.c MCP2517FD CAN FD Controller with SPI Interface Microchip Download
CE51X.c PIC16CE62X 8-Bit MCU with EEPROM Data Memory Microchip Download
CE62X.c PIC16CE62X 8-Bit MCU with EEPROM Data Memory Microchip Download
CE67X.c PIC12CE67X 8-Bit MCU with ADC and EEPROM Data Memory Microchip Download
compass.c PNI-11096 Drivers for the internal I2C EEPROM of the PIC12CE67x electronic compass PNI Corporation Download
cy62256.c CY62256N High Performance CMOS Static RAM Infineon/Cypress Download
d41256.c D41256 256KB dynamic memory device NEC OBSOLETE
ds1302.c DS1302 Serial real time clock Maxim/Dallas Download
ds1305.c DS1305 Serial real time clock Maxim/Dallas Download
ds1338.c DS1338 Serial real time clock Maxim/Dallas Download
ds1621.c DS1621 Serial digital thermometer Maxim/Dallas Download
ds1621m.c DS1621 Serial digital thermometer Maxim/Dallas Download
ds1624.c DS1624 Digital Thermometer and Memory Maxim/Dallas Download
ds1631.c DS1631 Digital Thermometer and Memory Maxim/Dallas Download
ds1631mm.c DS1631 Digital Thermometer and Memory (Multi-Master) Maxim/Dallas Download
ds1868.c DS1868 Serial, 2 channel, digital potentiometer Maxim/Dallas Download
ds1993.c DS1993 4kb Memory iButton Maxim/Dallas Download
ds2432.c DS2432 1KB EEPROM with SHA-1 Engine Maxim/Dallas Download
em4095.c EM4095 125kHz RFID Basestation EM Microelectronic Download
em4102.c EM4102 RF Transponder EM Microelectronic
em4150.c EM4150 RF Transponder EM Microelectronic
gp2d12.c GP2D12 Distance Measuring Sensors Sharp Download
hdm64gs12.c HDM64GS12 128 x 64 graphics LCD display Hantronix Download
hmc6042.c HMC6042 2-Axis Magnetic Sensor Circuit Honeywell Download
ht3223.c HT3223/HTF3223 Humidity Sensor Humirel OBSOLETE
isd4003.c ISD4003 Voice record/playback IC Nuvoton (ISD) Download
isl1209.c ISL1209 Real Time Clock/Calendar Intersil Download
kbd.c Various 3x4 keypads 3x4 Keypad Various Download
ks0108.c KS0108B LCD Controller Samsung Download
lcd.c Various 2x16 LCD screens 2x16 LCD Panel Various Download
lcd420.c Common 4x20 LCD modules LCD Terminal Various Download
LINBUS.h PIC16F687 Low Pin Count MCU Microchip Download
lm75cim3.c LM75CIM-3 I2C Temperature Chip Texas Instruments Download
lmx2326.c LMX2326 RF Personal Communications Texas Instruments Download
line_tracker.c QRB1134 Phototransistor Fairchild Download
ltc1298.c LTC1298 12-bit, serial ADC Linear Download
ltc2486.c LTC2486 16-bit, ADC with PGA Linear Download
m68af031.c M68AF031A 256KB Asynchronous SRAM STMicroelectronics Download
max517.c MAX517 1 channel serial DACs Maxim/Dallas Download
max7300.c MAX7300 20/28 Port IO Expander Maxim/Dallas Download
max7456.c MAX7456 Single-Channel Monochrome On-Screen Display with Integrated EEPROM Maxim/Dallas Download
mcp3204.c MCP3204 12-bit, SPI ADC Microchip Download
mcp3208.c MCP3208 12-bit, SPI ADC Microchip Download
mcp3421.c MCP3421 18-bit, I2C ADC Microchip Download
mcp342x.c MCP342x Delta-Sigma ADC Microchip Download
mcp4921.c MCP4921 12-bit, SPI DAC Microchip Download
mcp41010.c MCP41010-i/p Digital SPI Potentiometer Microchip Download
mcr.c V3A-6 Manual Swipe Magnetic Card Reader Omron Download
mt4264.c MT4264 Dynamic Memory Device Micron Technology OBSOLETE
n9085ud.c N9085UD VCR/TV remote Philips Magnavox
nju6355.c NJU6355 Serial RTC NJR Download
pcf8563.c PCF8563 Real-time clock/calendar NXP/Philips Download
pcf8570.c PCF8570 256 byte I2C RAM NXP/Philips Download
pic_usb.h PIC16C7X5 USB Microchip Download
pic16f_usb.h PIC16F1454 USB Microchip Download
pic18_usb.h PIC18 USB Microchip Download
pic24_usb.h PIC24 USB Microchip Download
pni11096.c PNI-11096 Electronic Compass PNI Corporation Download
rs485.c ADM1485 EIA RS-485 Transceiver Analog Devices Download
rtl8019.c RTL8019AS Ethernet Controller Realtek Download
s7600.h S-7600A TCP/IP Network Protocol LSI Seiko Instruments Download
sc28l19x.c SC28L19X Quad UART for 3.3V and 5V supply voltage NXP/Philips Download
sed1335.c SED1335 CMOS Graphic LCD Controller Densitron Download
servos.c S03N 2BB Standard Delux Ball Bearing Servo
sst25vf.c SST25VF020B Flash Memory Microchip Download
sst39sf010a.c SST39SF010A Multi-Purpose Flash Microchip Download
tlc545cn.c TLC545CN ADC Texas Instruments OBSOLETE
tlv320aic12k.c TLV320AIC12K 16-bit, 26-KSPS Mono Codec Texas Instruments Download
tlv320aic23b.c TLV320AIC23B Stereo Audio Codec Texas Instruments OBSOLETE
touch.c Various Dallas 1-Wire Buttons Wide range of applications, including ROM and thermometer Maxim/Dallas Download
usbn960x.c USBN960X USB Node Controller Texas Instruments Download
wts701.c WTS701 Text-to-Speech Processor Winbond Download
x10.c TW523 Power line communcation X10 Download
1937 Development Kit VIM-503-DP-RC-S-HV 4.5 Digit LCD Varitronix Download
CCS Wireless - Ember ZigBee Edition Development Kit NCP21XM472J03RA Thermistor Murata Download
CCS Wireless - Ember ZigBee Edition Development Kit L14F2 Phototransistor Fairchild Download
E3 GPS Module A2235-H GPS Receiver Maestro
7-segment LED LTS-6960HR 7-segment LED in the E3mini Advanced Accessories Kit LITE-ON Download
Accelerometer Sensor ADXL345 Accelerometer Sensor in the Sensors Explorer Kit Various Download
Barometer Sensor BMP180 Barometer Sensor in the Sensors Explorer Kit Various Download
Digital Temperature Sensor DS18B20 Digital Temperature Sensor in the Sensors Explorer Kit Various Download
