CCS PCD used for PIC24. If using PIC16 - any differences?
allenhuffman
PostPosted: Wed Jul 23, 2025 8:16 am     Reply with quote
We use PIC24 chips and the PCD CCS C Compiler.
Is what I am used to different for PIC16? If I needed to work on a PIC16 design, would PCD be the tool that would be used, or something different?
Using: 24FJ256GA106, 24EP256GP202 and 24FJ64GA002.
PostPosted: Wed Jul 23, 2025 8:46 am     Reply with quote
It would be a different compiler depending on "which" pic16 you are using (12bit or 14bit). See the diagram here:
https://www.ccsinfo.com/compilers.php
Now if you have PCWHD (vs just plain PCD), you can compile for any PIC CCS supports
allenhuffman
PostPosted: Wed Jul 23, 2025 9:12 am     Reply with quote
I suppose my actual question is ... will I know how to use it (same IDE) or is it a completely different thing? If they go with PIC16, and I already know how to use the tools and be productive immediately (Configuration Wizard and such), that's great.
If it's different and has to be learned, they might just go with the free tools from Microchip.
PostPosted: Wed Jul 23, 2025 9:32 am     Reply with quote
I don't know if it helps, but I'm using PCWHD (the IDE) and it is the same IDE for all chips.
dyeatman
PostPosted: Wed Jul 23, 2025 3:24 pm     Reply with quote
I use PCWHD with the CCS IDE and ICDU40.
Switching between 10,12,14, 16, 18, 24 and dspic is virtually seamless for me.
I use it the same for any chip I choose, with minor differences due to the
change in number of bits. (header settings typically, since many of
the lesser series lacks some peripherals in the 24.)
I run two instances of the IDE for multi-core chips
Google and Forum Search are some of your best tools!!!!
asmallri
PostPosted: Wed Jul 23, 2025 6:08 pm     Reply with quote
If you already are very familiar with PCD and like the tool chain then you would have to have rocks in your head to go down the completely broken path you are suggesting.
Regards, Andrew
PostPosted: Fri Jul 25, 2025 1:26 am     Reply with quote
Think of it being like the difference between driving a Ford [spam] and
a Fiesta. The ride is different because of the different size and weight,
but 95% of the controls are in exactly the same place. Some thins are
missing, and the performance is different, but very similar. Trying to switch
to the MicroChip system is like trying to change to a bus instead.
The biggest things to bear in mind, are the fuse settings, and the
sizes. Keeping it in your head that an 'int' is an int8, and that by default
variables are unsigned, is something you will need to keep reciting to
yourself when working on the smaller chips......
dyeatman
PostPosted: Fri Jul 25, 2025 3:48 am     Reply with quote
That's why I use int8, uint8, int16, uint16 etc. in all my code,. it is keeps that
from being an issue when switching chips or porting code.
PostPosted: Fri Jul 25, 2025 7:38 am     Reply with quote
Totally agreed. You will see that I recommend using the full names 'by
default'.
However, especially when including old code, or just being a bit 'casual',
it is easy to forget, especially the signed/unsigned part. Sad
asmallri
PostPosted: Fri Jul 25, 2025 7:44 am     Reply with quote
There is also the issue of "what if I want to modify a suppied driver"" to do something different. Pretty easy to do with CCS, a mind boggling complexity with the alterntive due to the very complex harmonized driver library.
Regards, Andrew
PostPosted: Fri Jul 25, 2025 8:47 am     Reply with quote
ah, but you NEVER modify a supplied driver !
You copy,save as MYdriver, THEN modify MYdriver.
That way you'll always have ORIGINAL driver to fall back on.
dyeatman
PostPosted: Fri Jul 25, 2025 9:13 am     Reply with quote
But also, the CCS drivers usually have the proper integer sizes/types already
so I don't typically have to make any changes to them.
asmallri
PostPosted: Fri Jul 25, 2025 7:42 pm     Reply with quote
I completly agree but also to support the other issue of a software update over writing your modified driver which would happen f you did not use the MYdriver method
Regards, Andrew
