allenhuffman
Joined: 17 Jun 2019 Posts: 660 Location: Des Moines, Iowa, USA
| CCS PCD used for PIC24. If using PIC16 - any differences? |
Posted: Wed Jul 23, 2025 8:16 am |
We use PIC24 chips and the PCD CCS C Compiler.
Is what I am used to different for PIC16? If I needed to work on a PIC16 design, would PCD be the tool that would be used, or something different? _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Embedded C, Arduino, MSP430, ESP8266/32, and PIC24 programmer.
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202, 24FJ64GA002 and 24FJ1024GA606. |
jeremiah
Posted: Wed Jul 23, 2025 8:46 am |
It would be a different compiler depending on "which" pic16 you are using (12bit or 14bit). See the diagram here:
https://www.ccsinfo.com/compilers.php
Now if you have PCWHD (vs just plain PCD), you can compile for any PIC CCS supports |
allenhuffman
Posted: Wed Jul 23, 2025 9:12 am |
| jeremiah wrote: | It would be a different compiler depending on "which" pic16 you are using (12bit or 14bit). See the diagram here:
I suppose my actual question is ... will I know how to use it (same IDE) or is it a completely different thing? If they go with PIC16, and I already know how to use the tools and be productive immediately (Configuration Wizard and such), that's great.
If it's different and has to be learned, they might just go with the free tools from Microchip. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
jeremiah
Posted: Wed Jul 23, 2025 9:32 am |
| allenhuffman wrote: |
If it's different and has to be learned, they might just go with the free tools from Microchip. |
I don't know if it helps, but I'm using PCWHD (the IDE) and it is the same IDE for all chips. |
Posted: Wed Jul 23, 2025 3:24 pm |
I use PCWHD with the CCS IDE and ICDU40.
Switching between 10,12,14, 16, 18, 24 and dspic is virtually seamless for me.
I use it the same for any chip I choose, with minor differences due to the
change in number of bits. (header settings typically, since many of
the lesser series lacks some peripherals in the 24.)
I run two instances of the IDE for multi-core chips _________________ Google and Forum Search are some of your best tools |
asmallri
Joined: 12 Aug 2004 Posts: 1661 Location: Perth, Australia
Posted: Wed Jul 23, 2025 6:08 pm |
| allenhuffman wrote: | | jeremiah wrote: | It would be a different compiler depending on "which" pic16 you are using (12bit or 14bit). See the diagram here:
If you already are very familiar with PCD and like the tool chain then you would have to have rocks in your head to go down the completely broken path you are suggesting. _________________ Regards, Andrew
Posted: Fri Jul 25, 2025 1:26 am |
Think of it being like the difference between driving a Ford [spam] and
a Fiesta. The ride is different because of the different size and weight,
but 95% of the controls are in exactly the same place. Some thins are
missing, and the performance is different, but very similar. Trying to switch
to the MicroChip system is like trying to change to a bus instead.
The biggest things to bear in mind, are the fuse settings, and the
sizes. Keeping it in your head that an 'int' is an int8, and that by default
variables are unsigned, is something you will need to keep reciting to
yourself when working on the smaller chips...... |
Posted: Fri Jul 25, 2025 3:48 am |
| Quote: | Keeping it in your head that an 'int' is an int8, and that by default
That's why I use int8, uint8, int16, uint16 etc. in all my code,. it is keeps that
from being an issue when switching chips or porting code. _________________ Google and Forum Search are some of your best tools |
Posted: Fri Jul 25, 2025 7:38 am |
Totally agreed. You will see that I recommend using the full names 'by
default'.
However, especially when including old code, or just being a bit 'casual',
it is easy to forget, especially the signed/unsigned part.  |
asmallri
Posted: Fri Jul 25, 2025 7:44 am |
| Ttelmah wrote: | Think of it being like the difference between driving a Ford [spam] and
There is also the issue of "what if I want to modify a suppied driver"" to do something different. Pretty easy to do with CCS, a mind boggling complexity with the alterntive due to the very complex harmonized driver library. _________________ Regards, Andrew
Joined: 01 Jul 2010 Posts: 9624 Location: Greensville,Ontario
Posted: Fri Jul 25, 2025 8:47 am |
ah, but you NEVER modify a supplied driver !
You copy,save as MYdriver, THEN modify MYdriver.
That way you'll always have ORIGINAL driver to fall back on. |
Posted: Fri Jul 25, 2025 9:13 am |
But also, the CCS drivers usually have the proper integer sizes/types already
so I don't typically have to make any changes to them. _________________ Google and Forum Search are some of your best tools |
asmallri
Posted: Fri Jul 25, 2025 7:42 pm |
| temtronic wrote: | ah, but you NEVER modify a supplied driver !
I completly agree but also to support the other issue of a software update over writing your modified driver which would happen f you did not use the MYdriver method _________________ Regards, Andrew
