Jody
| fprintf and usb_cdc_putc stream |
Posted: Tue Aug 23, 2022 1:21 am |
What I am trying to do:
Send a string and a variable to the usb.
PIC send and receive single strings.. when using the printf command i.e.: | Code: | | printf(usb_cdc_putc,"Tel_Temp 1 number :); |
this working ..
but when i do this:
| Code: | | fprintf(usb_cdc_putc,"Tel_Temp 1 number : %s", tel_temp1); |
the compiler complains: Stream must be a constant in the valid range .
And I don't understand what the problem is..
When I use the same command to a different stream it is fine...
so this goes with no problem: | Code: | | fprintf(RS232,"Tel_Temp 1 number : %s\n", tel_temp1) |
what am I doing wrong??
Best regards,
Jody |
Posted: Tue Aug 23, 2022 10:32 am |
fprint, prints to streams.
usb_cdc_putc, is _not_ a stream. It is a output function for the usb.
You don't want to be using the stream function. Just:
printf, can write to any output function. |
