fprintf and usb_cdc_putc stream
Jody
PostPosted: Tue Aug 23, 2022 1:21 am     Reply with quote
What I am trying to do:
Send a string and a variable to the usb.
PIC send and receive single strings.. when using the printf command i.e.:
printf(usb_cdc_putc,"Tel_Temp 1 number  :);
this working ..
but when i do this:
fprintf(usb_cdc_putc,"Tel_Temp 1 number  : %s", tel_temp1);
the compiler complains: Stream must be a constant in the valid range .
And I don't understand what the problem is..
When I use the same command to a different stream it is fine...
so this goes with no problem:
fprintf(RS232,"Tel_Temp 1 number  : %s\n", tel_temp1)
what am I doing wrong??
Best regards,
Jody
PostPosted: Tue Aug 23, 2022 10:32 am     Reply with quote
fprint, prints to streams.
usb_cdc_putc, is _not_ a stream. It is a output function for the usb.
You don't want to be using the stream function. Just:
printf, can write to any output function.
