		| Author | Message |
		| beaker404
				| SPI 16B address  and 8b data |
				|  Posted: Mon Aug 15, 2022 12:20 pm |   |
				| CCS 5.064 PIC18F26K22
 EEPROM  93LC66C
 Looked around the forum and nothing came out as an exact solution to my problem,
 problem being, using a 93LC66 in 8b data mode so 512 x 8 bytes.
 Communication is via SPI and works find IF I stay below an address of 255
 and I know why, the SPI is only sending 8b of address, tried sending MSB and LSB of the address word, did not work.
 Is there a way to get a 16b address to the EEPROM followed by the 8b data?  Perhaps I just do not get SPI well enough to resolve it.
 SPI set up like this: for 8b data, this all works just not when I try to do 16b addressing.
  	  | Code: |  	  | #DEFINE SPI_XFER_9356(x)   spi_xfer(SPI2_EEPROM, x)
 #DEFINE  EEPROM_ADDRESS unsigned long
 #use spi(master, DO=Pin_B3, CLK=PIN_B1, DI=PIN_B2 ,ENABLE_ACTIVE=1, ENABLE_DELAY=20,mode=0, baud=2000000, stream=SPI2_EEPROM, bits=8, FORCE_SW)
 my write function:
  	  | Code: |  	  | void write_ext_eeprom(EEPROM_ADDRESS address, BYTE data) {
 disable_interrupts(global);
 output_high(EEPROM_SELECT);
 SPI_XFER_9356(0xa);
 SPI_XFER_9356(address);
 SPI_XFER_9356(data);
 output_low(EEPROM_SELECT);
 delay_ms(11);
 enable_interrupts(global);
 my read function:
  	  | Code: |  	  | BYTE read_ext_eeprom(EEPROM_ADDRESS address) {
 BYTE data;
 SPI_XFER_9356(0xc);
 data=SPI_XFER_9356(0);
 return(data);
		| beaker404
				|  Posted: Mon Aug 15, 2022 12:22 pm |   |
				| sorry for the poor formatting of the thread, for some reason I cannot edit it now correctly. |  |
		| gaugeguy
				|  Posted: Mon Aug 15, 2022 12:43 pm |   |
				| To access addresses 256-511, the high address bit is the low bit of the command.
  	  | Code: |  	  | output_high(EEPROM_SELECT);
 SPI_XFER_9356(0x0c | 0x01);  // command and high bit of address
 SPI_XFER_9356(address);  // low 8 bits of address
		| beaker404
				|  Posted: Mon Aug 15, 2022 1:14 pm |   |
				| thanks. Not sure how I missed that in the datasheet,
 | You cannot post new topics in this forum You cannot reply to topics in this forum
