SPI 16B address and 8b data
beaker404
PostPosted: Mon Aug 15, 2022 12:20 pm     Reply with quote
CCS 5.064
PIC18F26K22
EEPROM 93LC66C
Looked around the forum and nothing came out as an exact solution to my problem,
problem being, using a 93LC66 in 8b data mode so 512 x 8 bytes.
Communication is via SPI and works find IF I stay below an address of 255
and I know why, the SPI is only sending 8b of address, tried sending MSB and LSB of the address word, did not work.
Is there a way to get a 16b address to the EEPROM followed by the 8b data? Perhaps I just do not get SPI well enough to resolve it.
SPI set up like this: for 8b data, this all works just not when I try to do 16b addressing.
#DEFINE SPI_XFER_9356(x)   spi_xfer(SPI2_EEPROM, x)
#DEFINE  EEPROM_ADDRESS unsigned long
#use spi(master, DO=Pin_B3, CLK=PIN_B1, DI=PIN_B2 ,ENABLE_ACTIVE=1, ENABLE_DELAY=20,mode=0, baud=2000000, stream=SPI2_EEPROM, bits=8, FORCE_SW)
my write function:
void write_ext_eeprom(EEPROM_ADDRESS address, BYTE data)
  disable_interrupts(global);
   output_high(EEPROM_SELECT);
   SPI_XFER_9356(0xa);
   SPI_XFER_9356(address);
   SPI_XFER_9356(data);
   output_low(EEPROM_SELECT);
   delay_ms(11);
   enable_interrupts(global);
my read function:
BYTE read_ext_eeprom(EEPROM_ADDRESS address)
   BYTE data;
   SPI_XFER_9356(0xc);
   data=SPI_XFER_9356(0);
   return(data);
beaker404
PostPosted: Mon Aug 15, 2022 12:22 pm     Reply with quote
sorry for the poor formatting of the thread, for some reason I cannot edit it now correctly.
gaugeguy
PostPosted: Mon Aug 15, 2022 12:43 pm     Reply with quote
To access addresses 256-511, the high address bit is the low bit of the command.
SPI_XFER_9356(0x0c | 0x01);  // command and high bit of address
SPI_XFER_9356(address);  // low 8 bits of address
beaker404
PostPosted: Mon Aug 15, 2022 1:14 pm     Reply with quote
thanks.
Not sure how I missed that in the datasheet,
