ToperaGarimpero
| Controlling RA6963 240x128 LCD with pic 16f877a |
Posted: Fri Apr 29, 2022 11:53 am |
Hello, I have been trying to make a Chinese lcd module to work, but so far, not even the contrast is working.
I'm using the code and libraries from this old post:
http://www.ccsinfo.com/forum/viewtopic.php?t=49389&highlight=t6963
And the lcd's pinout is in this chart.
https://imgur.com/a/PqYW1HW
One issue that I've found is that there's no negative voltage on Vee, and using an external power supply doesn't seem to make the contrast potentiometer to work.
Does anyone know what I could've been doing wrong? |
Posted: Fri Apr 29, 2022 1:56 pm |
| Post a link to the data sheet for the LCD. Or the website for it. |
Joined: 01 Jul 2010 Posts: 9641 Location: Greensville,Ontario
Posted: Fri Apr 29, 2022 2:46 pm |
YES, need to KNOW what LCD module it is.. !!
Is it JUST the actual chip or a premade PCB with LCD,controller and 'connections' ??
I downloaded a manual Vee is mentioned as YOu supply it.
No Vee ? maybe YOU have to supply it ??
Some modules actually have the VEE electronics onboard...some don't.... |
Posted: Sat Apr 30, 2022 5:18 am |
Yes.
We need to know what the module actually 'is'.
The voltage needed for Vee, depends of the display technology involved.
I have seen units needing voltages between -10v, and +4v. In many
cases different colour versons of the same display will need massively
different voltages on this.
We can't actually help you unless you tell us the unit involved. |
Posted: Sat Apr 30, 2022 7:50 am |
I had one that spec said it needed -19 volts. I 'borrowed' some electrons from the -15 for the op amps in that project.....
The other possible problem is that's a 5 volt PIC, so IS the LCD module a true 5 volt device or really 3 volt Vdd with 5 v 'tolerant' I/O pins ?? |
