Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
Controlling RA6963 240x128 LCD with pic 16f877a
ToperaGarimpero
PostPosted: Fri Apr 29, 2022 11:53 am     Reply with quote
Hello, I have been trying to make a Chinese lcd module to work, but so far, not even the contrast is working.
I'm using the code and libraries from this old post:
http://www.ccsinfo.com/forum/viewtopic.php?t=49389&highlight=t6963
And the lcd's pinout is in this chart.
https://imgur.com/a/PqYW1HW
One issue that I've found is that there's no negative voltage on Vee, and using an external power supply doesn't seem to make the contrast potentiometer to work.
Does anyone know what I could've been doing wrong?
PostPosted: Fri Apr 29, 2022 1:56 pm     Reply with quote
Post a link to the data sheet for the LCD. Or the website for it.
PostPosted: Fri Apr 29, 2022 2:46 pm     Reply with quote
YES, need to KNOW what LCD module it is.. !!
Is it JUST the actual chip or a premade PCB with LCD,controller and 'connections' ??
I downloaded a manual Vee is mentioned as YOu supply it.
No Vee ? maybe YOU have to supply it ??
Some modules actually have the VEE electronics onboard...some don't....
PostPosted: Sat Apr 30, 2022 5:18 am     Reply with quote
Yes.
We need to know what the module actually 'is'.
The voltage needed for Vee, depends of the display technology involved.
I have seen units needing voltages between -10v, and +4v. In many
cases different colour versons of the same display will need massively
different voltages on this.
We can't actually help you unless you tell us the unit involved.
PostPosted: Sat Apr 30, 2022 7:50 am     Reply with quote
I had one that spec said it needed -19 volts. I 'borrowed' some electrons from the -15 for the op amps in that project..... Very Happy
The other possible problem is that's a 5 volt PIC, so IS the LCD module a true 5 volt device or really 3 volt Vdd with 5 v 'tolerant' I/O pins ??
