Issue with ieeefloat.c on the Q43 chips
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CCS Forum Index -> Known Issues
PostPosted: Sun Dec 19, 2021 7:46 am     Reply with quote
This thread shows an issue that has been identified with this library and these
chips. Hopefully will be fixed soon.
http://www.ccsinfo.com/forum/viewtopic.php?t=59607
It is because the Q43 chi0ps have the bottom area of their 'RAM' memory
map containing fast access versions of the SFR's, which prevents the
#locate used to address 0x20 from working.
I have a patched library that fixes this if needed.
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CCS Forum Index -> Known Issues All times are GMT - 6 Hours
