CCS has impressive bit handling.
allenhuffman
PostPosted: Tue Feb 25, 2020 1:35 pm     Reply with quote
I read about int1, but never used it. The compiler will use one byte for up to 8 of those:
int1 bit1;
int1 bit2;
int1 bit3;
int1 bit4;
int1 bit5;
int1 bit6;
int1 bit7;
   bit0 = 1;
   bit1 = 0;
   bit2 = 1;
   bit3 = 0;
   bit4 = 1;
   bit5 = 0;
   bit6 = 1;
   bit7 = 0;
Those turn into nice atomic assembly calls:
....................    bit0 = 1;
00228:  BSET.B  800.0
....................    bit1 = 0;
0022A:  BCLR.B  800.1
....................    bit2 = 1;
0022C:  BSET.B  800.2
....................    bit3 = 0;
0022E:  BCLR.B  800.3
....................    bit4 = 1;
00230:  BSET.B  800.4
....................    bit5 = 0;
00232:  BCLR.B  800.5
....................    bit6 = 1;
00234:  BSET.B  800.6
....................    bit7 = 0;
00236:  BCLR.B  800.7
So I wondered how different it was to doing it manually.
Just SETTING a bit like this is larger:
....................    byte = (1 << 4);
00238:  MOV.B   #10,W0L
0023A:  MOV.B   W0L,801
But ORing a bit generates the same nice code without needing to use non-standard int1:
....................    byte = byte | (1 << 4);
0023C:  BSET.B  801.4
Clearing a bit also generates one atomic instruction:
....................    byte = byte & ~(1 << 4);
0023E:  BCLR.B  801.4
Kudos to CCS. It's nice seeing int1 available, but nicer seeing the compiler is smart enough to do bit set/clear efficiently if you are manually doing it.
I created Arduino-compatible bit macros and worried they might generate bulky code, but I never checked until now:
....................    byte = bitSet(byte, 4);
0023C:  BSET.B  801.4
....................    byte = bitClear(byte, 4);
00242:  BCLR.B  801.4
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202 and 24FJ64GA002.
PostPosted: Tue Feb 25, 2020 5:19 pm     Reply with quote
Really has nothing to do with CCS, thank MICROCHIP ! They're the ones that embedded bit instructions in the PIC !!
allenhuffman
PostPosted: Wed Feb 26, 2020 1:32 pm     Reply with quote
I am glad to give credit to CCS for actually taking advantage of it Smile I've seem some terrible code generation over the years, so I'm always pleased when I see a compiler doing something smart.
I noticed that bit set/clear when looking at the I2C assembly. Nice.
