allenhuffman
Joined: 17 Jun 2019 Posts: 644 Location: Des Moines, Iowa, USA
| CCS has impressive bit handling. |
Posted: Tue Feb 25, 2020 1:35 pm |
I read about int1, but never used it. The compiler will use one byte for up to 8 of those:
| Code: | int1 bit1;
int1 bit2;
int1 bit3;
int1 bit4;
int1 bit5;
int1 bit6;
int1 bit7;
bit0 = 1;
bit1 = 0;
bit2 = 1;
bit3 = 0;
bit4 = 1;
bit5 = 0;
bit6 = 1;
bit7 = 0;
Those turn into nice atomic assembly calls:
| Code: | .................... bit0 = 1;
00228: BSET.B 800.0
.................... bit1 = 0;
0022A: BCLR.B 800.1
.................... bit2 = 1;
0022C: BSET.B 800.2
.................... bit3 = 0;
0022E: BCLR.B 800.3
.................... bit4 = 1;
00230: BSET.B 800.4
.................... bit5 = 0;
00232: BCLR.B 800.5
.................... bit6 = 1;
00234: BSET.B 800.6
.................... bit7 = 0;
00236: BCLR.B 800.7 |
So I wondered how different it was to doing it manually.
Just SETTING a bit like this is larger:
| Code: | .................... byte = (1 << 4);
00238: MOV.B #10,W0L
0023A: MOV.B W0L,801 |
But ORing a bit generates the same nice code without needing to use non-standard int1:
| Code: | .................... byte = byte | (1 << 4);
0023C: BSET.B 801.4 |
Clearing a bit also generates one atomic instruction:
| Code: | .................... byte = byte & ~(1 << 4);
0023E: BCLR.B 801.4 |
Kudos to CCS. It's nice seeing int1 available, but nicer seeing the compiler is smart enough to do bit set/clear efficiently if you are manually doing it.
I created Arduino-compatible bit macros and worried they might generate bulky code, but I never checked until now:
| Code: | .................... byte = bitSet(byte, 4);
0023C: BSET.B 801.4
.................... byte = bitClear(byte, 4);
00242: BCLR.B 801.4 |
_________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202 and 24FJ64GA002. |
Joined: 01 Jul 2010 Posts: 9608 Location: Greensville,Ontario
Posted: Tue Feb 25, 2020 5:19 pm |
| Really has nothing to do with CCS, thank MICROCHIP ! They're the ones that embedded bit instructions in the PIC !! |
allenhuffman
Posted: Wed Feb 26, 2020 1:32 pm |
| temtronic wrote: | | Really has nothing to do with CCS, thank MICROCHIP ! They're the ones that embedded bit instructions in the PIC !! |
I am glad to give credit to CCS for actually taking advantage of it I've seem some terrible code generation over the years, so I'm always pleased when I see a compiler doing something smart.
I noticed that bit set/clear when looking at the I2C assembly. Nice. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
