| View previous topic :: View next topic   |
			SamMeredith
				| Printf() with %w format and leading zeros |
				 Posted: Wed Feb 19, 2020 6:14 am     |
				I am getting unexpected output from the printf() family when using the %w format code with leading zeros (e.g "%05.2w").
I am using compiler version 5.078
#include <33EP512MC806.h>
#include <stdint.h>
#use delay(crystal = 12Mhz, clock = 120Mhz, AUX:clock = 48Mhz)
#pin_select U3RX = PIN_F1
#pin_select U3TX = PIN_F2
#use rs232(UART3, baud = 115200, parity = N, bits = 8, errors, TIMEOUT = 1, stream = DEBUG)
void main() {
    int32_t value = 0x00000039;
    fprintf(DEBUG, "\r\n%4d", value);       // Outputs "  57" as expected
    fprintf(DEBUG, "\r\n%5.2w", value);     // Outputs " 0.57" as expected
    fprintf(DEBUG, "\r\n%05.2w", value);    // Outputs "00000000.57" I expcted "00.57"
Any idea what is going on here? |
				 Posted: Wed Feb 19, 2020 7:37 am     |
				I'd talk to CCS.
It definitely looks wrong. In multiple ways!...
It actually looks as if with the leading 0 selected, it is outputting zeros
for the entire 32bit value, and ignoring the digit number it is being given!...
Ugh!...
There is another fault here I found while testing this. Change the number to
0x139, and it prints:
 313
 3.10
00000003.10
It is losing the last digit of the number!...
You really should be using %lw. int32, is a 'long', and without this it'll
lose data when the number goes over 65535. However it does exactly the
same with an int16, or with the 'L' there!... |
			SamMeredith
				 Posted: Wed Feb 19, 2020 7:55 am     |
				Thanks Ttelmah.
I hadn't realised lw was needed, I'll be sure to use that.
I actually did spot the fault you mention when I went to build the posted MWE. Did you test my example code under MPLAB's simulator by any chance?
When I run my example on the real hardware I get the outputs above but when I run it on the MPLAB simulator I get:
  57
 0.51
00000000.51
I've worked around the issue for now by manually adding the leading zeros. I will contact CCS about a real fix.
				 Posted: Wed Feb 19, 2020 8:16 am     |
				Yes I did use the simulator. Quick way to test.
That's good if it is only a simulator fault. Thought I would have seen
it if it was doing it for 'real', since I do use %lw in quite a few places.
However I don't use leading zeros, so hadn't spotted your main one!...
Actually, update on this. MPLAB-X simulates it OK. The fault is only
with the old MPLAB 8.92 simulator. |
			dluu13
				 Posted: Thu Feb 20, 2020 4:39 pm     |
				| I had this same bug a while ago on PCD but I was on 5.082. CCS sent me updated compiler v5.085 to fix this. |
				 Posted: Fri Feb 21, 2020 1:42 am     |
				Just tested with 5.085, and it does the same.
Looks as if the fix got 'forgotten', and has not been included in the release
compiler...    |
			dluu13
				 Posted: Fri Feb 21, 2020 6:21 am     |
				Oh, I wasn't clear.
I had other problems with %w and lw format specifiers where I would just get totally unrelated numbers.
Even now, after the fix, there are some output glitches occasionally so I totally gave up on using lw and w... I wrote a function that converts a number to BCD and prints it out with a string and places a decimal point where I want:
http://www.ccsinfo.com/forum/viewtopic.php?t=58018 |
