Printf() with %w format and leading zeros
SamMeredith
PostPosted: Wed Feb 19, 2020 6:14 am     Reply with quote
I am getting unexpected output from the printf() family when using the %w format code with leading zeros (e.g "%05.2w").
I am using compiler version 5.078
#include <33EP512MC806.h>
#include <stdint.h>
#use delay(crystal = 12Mhz, clock = 120Mhz, AUX:clock = 48Mhz)
#pin_select U3RX = PIN_F1
#pin_select U3TX = PIN_F2
#use rs232(UART3, baud = 115200, parity = N, bits = 8, errors, TIMEOUT = 1, stream = DEBUG)
void main() {
    int32_t value = 0x00000039;
    fprintf(DEBUG, "\r\n%4d", value);       // Outputs "  57" as expected
    fprintf(DEBUG, "\r\n%5.2w", value);     // Outputs " 0.57" as expected
    fprintf(DEBUG, "\r\n%05.2w", value);    // Outputs "00000000.57" I expcted "00.57"
Any idea what is going on here?
PostPosted: Wed Feb 19, 2020 7:37 am     Reply with quote
I'd talk to CCS.
It definitely looks wrong. In multiple ways!...
It actually looks as if with the leading 0 selected, it is outputting zeros
for the entire 32bit value, and ignoring the digit number it is being given!...
Ugh!...
There is another fault here I found while testing this. Change the number to
0x139, and it prints:
313
3.10
00000003.10
It is losing the last digit of the number!...
You really should be using %lw. int32, is a 'long', and without this it'll
lose data when the number goes over 65535. However it does exactly the
same with an int16, or with the 'L' there!...
SamMeredith
PostPosted: Wed Feb 19, 2020 7:55 am     Reply with quote
Thanks Ttelmah.
I hadn't realised lw was needed, I'll be sure to use that.
I actually did spot the fault you mention when I went to build the posted MWE. Did you test my example code under MPLAB's simulator by any chance?
When I run my example on the real hardware I get the outputs above but when I run it on the MPLAB simulator I get:
57
0.51
00000000.51
I've worked around the issue for now by manually adding the leading zeros. I will contact CCS about a real fix.
PostPosted: Wed Feb 19, 2020 8:16 am     Reply with quote
Yes I did use the simulator. Quick way to test.
That's good if it is only a simulator fault. Thought I would have seen
it if it was doing it for 'real', since I do use %lw in quite a few places.
However I don't use leading zeros, so hadn't spotted your main one!...
Actually, update on this. MPLAB-X simulates it OK. The fault is only
with the old MPLAB 8.92 simulator.
dluu13
PostPosted: Thu Feb 20, 2020 4:39 pm     Reply with quote
I had this same bug a while ago on PCD but I was on 5.082. CCS sent me updated compiler v5.085 to fix this.
PostPosted: Fri Feb 21, 2020 1:42 am     Reply with quote
Just tested with 5.085, and it does the same.
Looks as if the fix got 'forgotten', and has not been included in the release
compiler... Sad
dluu13
PostPosted: Fri Feb 21, 2020 6:21 am     Reply with quote
Oh, I wasn't clear.
I had other problems with %w and lw format specifiers where I would just get totally unrelated numbers.
Even now, after the fix, there are some output glitches occasionally so I totally gave up on using lw and w... I wrote a function that converts a number to BCD and prints it out with a string and places a decimal point where I want:
http://www.ccsinfo.com/forum/viewtopic.php?t=58018
