Using MFRC522 RFID Reader with PIC16F877
Goto page Previous  1, 2
PostPosted: Sat Jul 27, 2019 12:52 pm     Reply with quote
bharath0209 wrote:
// Note:Connect MFRC522 module to 5v PIC without any Level converter.
// It'll work fine.
I had to increase the supply voltage to 3.7 volts for it to work perfectly.
This strongly indicates a level-shifter issue. You are probably missing the
level shifter circuits. Look at the schematic for your MFRC522 product.
Does it have built-in level shifter circuits ?
myloudharim
PostPosted: Thu Mar 18, 2021 10:55 pm     Reply with quote
Did you correct spi write function?
void spi_write(byte value )
   SSPBUF = dat;
Should be
   SSPBUF = value;
PostPosted: Sat Mar 20, 2021 11:47 am     Reply with quote
That function is commented out in his code, and is not used.
It doesn't matter.
Page 2 of 2
