// Note:Connect MFRC522 module to 5v PIC without any Level converter.
// It'll work fine.
I had to increase the supply voltage to 3.7 volts for it to work perfectly.
This strongly indicates a level-shifter issue. You are probably missing the
level shifter circuits. Look at the schematic for your MFRC522 product.
Does it have built-in level shifter circuits ?
myloudharim
Posted: Thu Mar 18, 2021 10:55 pm
Did you correct spi write function?
void spi_write(byte value )
SSPBUF = dat;
Should be
SSPBUF = value;
Posted: Sat Mar 20, 2021 11:47 am
That function is commented out in his code, and is not used.
It doesn't matter.
Page 2 of 2
