emyeuKH
| 4x4 keypad driver |
Posted: Tue Sep 22, 2015 10:45 pm |
Hi all
I have some problems about keyboard. I use driver which is modified by PCM Programmer and set name: keyboard.c.
http://www.ccsinfo.com/forum/viewtopic.php?t=28022&start=14
Rows have external pull-up resistor (4k7). But don't have anything appear on screen LCD. Please explain to me how to show it. I use pic16F877A, portD for LCD, want to use portC for keyboard. The other port for the other task. Thank you very much for helping.
This is driver keyboard.c
//Keypad connection:
#define row0 PIN_C4
#define row1 PIN_C5
#define row2 PIN_C6
#define row3 PIN_C7
#define col0 PIN_C0
#define col1 PIN_C1
#define col2 PIN_C2
#define col3 PIN_C3
// Keypad layout:
char const KEYS[4][4] =
{{'1','2','3','U'},
{'4','5','6','D'},
{'7','8','9','C'},
{'0','.','F','S'}};
#define KBD_DEBOUNCE_FACTOR 33 // Set this number to apx n/333 where
// n is the number of times you expect
// to call kbd_getc each second
void kbd_init()
//set_tris_c(0xF0);
//output_c(0xF0);
//port_b_pullups(true);
short int ALL_ROWS (void)
if(input (row0) & input (row1) & input (row2) & input (row3))
return (0);
return (1);
char kbd_getc()
static byte kbd_call_count;
static short int kbd_down;
static char last_key;
static byte col;
byte kchar;
byte row;
kchar='\0';
if(++kbd_call_count>KBD_DEBOUNCE_FACTOR)
switch (col)
case 0:
output_low(col0);
output_high(col1);
output_high(col2);
output_high(col3);
case 1:
output_high(col0);
output_low(col1);
output_high(col2);
output_high(col3);
case 2:
output_high(col0);
output_high(col1);
output_low(col2);
output_high(col3);
case 3:
output_high(col0);
output_high(col1);
output_high(col2);
output_low(col3);
if(kbd_down)
if(!ALL_ROWS())
kbd_down=false;
kchar=last_key;
last_key='\0';
if(ALL_ROWS())
if(!input (row0))
row=0;
else if(!input (row1))
row=1;
else if(!input (row2))
row=2;
else if(!input (row3))
row=3;
last_key =KEYS[row][col];
kbd_down = true;
++col;
if(col==4)
col=0;
kbd_call_count=0;
return(kchar);
This is my code:
#include <16F877A.h>
#include <define_877A.h>
#FUSES HS, NOWDT, NOBROWNOUT, NOLVP, NOPROTECT
#device *=16 ADC=8
#use delay(crystal=12000000)
#define LED PIN_D0
#define LCD_RS_PIN PIN_D1
#define LCD_RW_PIN PIN_D2
#define LCD_ENABLE_PIN PIN_D3
#define LCD_DATA4 PIN_D4
#define LCD_DATA5 PIN_D5
#define LCD_DATA6 PIN_D6
#define LCD_DATA7 PIN_D7
#include <lcd.c>
#include <keyboard.c>
{ char k;
kbd_init();
lcd_init();
lcd_cursor_on(false);
while(true)
{ k=kbd_getc();
printf(lcd_putc,"\f %c",k);
output_toggle(LED);
delay_ms(200);
// 1 2 3 Up
// 4 5 6 Down
// 7 8 9 Clear
// 0 . Defaut Set |
asmboy
Posted: Wed Sep 23, 2015 1:26 pm |
| Quote: | while(true)
k=kbd_getc();
output_toggle(LED);
delay_ms(200);
Your polling loop is wrong. Most of the time, kbd_getc() will return 0.
Look at the code in main() in the link to the keypad driver. It only does
something if k is non-zero. It tests k with an if() statement to see if
it is non-zero. Modify your loop to do it the same way. |
