18F45K50
in_nursery
18F45K50
PostPosted: Tue May 19, 2015 10:17 am     Reply with quote
Hi all
I try to use a 18F45K50 but I have a strange problem.
#include <18F45K50.h>
#fuses   INTRC       // Internal RC Osc
void main() {
setup_oscillator(OSC_4MHZ|OSC_INTRC);
output_high(PIN_B5);
When I build in debug mode the output goes up.
When I build in release mode the output is not working.
Thanks in advance for your help.
PostPosted: Tue May 19, 2015 7:24 pm     Reply with quote
Do you have a pull-up resistor on your MCLR pin ? This will be a 10K
resistor if you use Microchip ICD3, or 47K if you use CCS ICD-U64.
in_nursery
PostPosted: Wed May 20, 2015 5:44 am     Reply with quote
yes The hardware is good
Finally it works with adding
#fuses  NOICPRT      // ICPRT disabled
but I don't understand why I need to disable it.
PostPosted: Wed May 20, 2015 7:05 am     Reply with quote
Read the data sheet....
3: Available only on 44-pin TQFP package devices. Program this bit clear on all other devices.
It _must_ be disabled on 'all other devices'.....
in_nursery
PostPosted: Wed May 20, 2015 7:21 am     Reply with quote
I use 44 pin TQFP
PostPosted: Wed May 20, 2015 7:40 am     Reply with quote
If so, setting the fuse, enables this feature, but then the resistor must be present on the clock line to bias this 'off' or the chip won't run, except with a debugger connected.....
in_nursery
PostPosted: Wed May 20, 2015 8:37 am     Reply with quote
ok thanks
