in_nursery
18F45K50 |
Posted: Tue May 19, 2015 10:17 am |
Hi all
I try to use a 18F45K50 but I have a strange problem.
Code: | #include <18F45K50.h>
#fuses INTRC // Internal RC Osc
setup_oscillator(OSC_4MHZ|OSC_INTRC);
output_high(PIN_B5);
When I build in debug mode the output goes up.
When I build in release mode the output is not working.
Thanks in advance for your help. |
Posted: Tue May 19, 2015 7:24 pm |
Do you have a pull-up resistor on your MCLR pin ? This will be a 10K
resistor if you use Microchip ICD3, or 47K if you use CCS ICD-U64. |
in_nursery
Posted: Wed May 20, 2015 5:44 am |
yes The hardware is good
Finally it works with adding
Code: | #fuses NOICPRT // ICPRT disabled |
but I don't understand why I need to disable it. |
Posted: Wed May 20, 2015 7:05 am |
Read the data sheet....
3: Available only on 44-pin TQFP package devices. Program this bit clear on all other devices.
It _must_ be disabled on 'all other devices'..... |
in_nursery
Posted: Wed May 20, 2015 7:21 am |
I use 44 pin TQFP |
Posted: Wed May 20, 2015 7:40 am |
If so, setting the fuse, enables this feature, but then the resistor must be present on the clock line to bias this 'off' or the chip won't run, except with a debugger connected..... |
in_nursery
Posted: Wed May 20, 2015 8:37 am |
ok thanks |
