Reliable Data Link for Cheap RF Modules
sshahryiar
PostPosted: Sun May 03, 2015 11:29 am     Reply with quote
TX
#include <12F629.h>
#device *= 16
#fuses NOWDT, PROTECT, CPD, INTRC_IO, PUT, BROWNOUT, NOMCLR
#use delay (internal = 4MHz)
#use RS232 (xmit = pin_A5, rcv = pin_A4, baud = 1200, stop = 1, parity = N)
#define BT1      input(pin_A0)
#define BT2      input(pin_A1)
#define BT3      input(pin_A2)
#define BT4      input(pin_A3)
void setup();
void send_data(unsigned char value);
   setup();
      if(BT1)
         while(BT1);
         send_data(0x04);
      if(BT2)
         while(BT2);
         send_data(0x06);
      if(BT3)
         while(BT3);
         send_data(0x09);
      if(BT4)
         while(BT4);
         send_data(0x11);
void setup()
   disable_interrupts(global);
   setup_timer_0(T0_internal);
   setup_timer_1(T1_disabled);
   set_timer0(0);
   set_timer1(0);
   unsigned char s = 0;
   unsigned char hb = 0;
   unsigned char lb = 0;
   unsigned long temp = 0;
   for(s = 0; s < 8; s++)
      temp <<= 2;
      if((value & 0x80) != 0)
          temp |= 0x1;
         temp |= 0x2;
      value <<= 1;
   hb = ((temp & 0xFF00) >> 8);
   lb = (temp & 0x00FF);
   for(s = 0; s < 2; s++)
      putc(0x00);
      putc(0x55);
      putc(hb);
      putc(lb);
      putc(hb & lb);
      putc(0xAA);
      delay_ms(40);
RX
#include <16F630.h>
#device *= 16
#fuses NOMCLR, NOWDT, PROTECT, CPD, INTRC_IO, BROWNOUT
#use RS232 (xmit = pin_C5, rcv = pin_C4, baud = 1200, stop = 1, parity = N)
#define OUT1      pin_C0
#define OUT2      pin_C1
#define OUT3      pin_C2
#define OUT4      pin_C3
void setup();
unsigned char receive_data();
    unsigned char value = 0;
   setup();
         value = receive_data();
         if(value == 0x04)
            output_toggle(OUT1);
         if(value == 0x06)
            output_toggle(OUT2);
         if(value == 0x09)
            output_toggle(OUT3);
         if(value == 0x11)
            output_toggle(OUT4);
void setup()
   set_timer0(0);
   set_timer1(0);
   unsigned char cmd[4];
   unsigned char tmp1 = 0;
   unsigned char tmp2 = 0;
   if(kbhit())
      if(getc() == 0x55)
         for(s = 0; s < 4; s++)
             cmd[s] = getc();
         tmp1 = cmd[0];
           tmp2 = cmd[1];
         if(((tmp2 & tmp1) == cmd[2]) && (cmd[3] == 0xAA))
            temp = tmp1;
            temp <<= 8;
            temp |= tmp2;
            tmp2 = 0;
               tmp2 <<= 1;
               if((temp & 0xC000) == 0x8000)
                  tmp2 |= 0x00;
               else if((temp & 0xC000) == 0x4000)
                  tmp2 |= 0x01;
                                        temp <<= 2;
   return tmp2;
https://www.facebook.com/MicroArena
SShahryiar
robo_z
PostPosted: Sat Aug 08, 2015 3:03 pm     Reply with quote
Thanks 4 Share
Very Happy
