sshahryiar
Joined: 05 May 2010 Posts: 94 Location: Dhaka, Bangladesh
| Reliable Data Link for Cheap RF Modules |
Posted: Sun May 03, 2015 11:29 am |
TX
| Code: | #include <12F629.h>
#device *= 16
#fuses NOWDT, PROTECT, CPD, INTRC_IO, PUT, BROWNOUT, NOMCLR
#use delay (internal = 4MHz)
#use RS232 (xmit = pin_A5, rcv = pin_A4, baud = 1200, stop = 1, parity = N)
#define BT1 input(pin_A0)
#define BT2 input(pin_A1)
#define BT3 input(pin_A2)
#define BT4 input(pin_A3)
void setup();
void send_data(unsigned char value);
setup();
if(BT1)
while(BT1);
send_data(0x04);
if(BT2)
while(BT2);
send_data(0x06);
if(BT3)
while(BT3);
send_data(0x09);
if(BT4)
while(BT4);
send_data(0x11);
void setup()
disable_interrupts(global);
setup_timer_0(T0_internal);
setup_timer_1(T1_disabled);
set_timer0(0);
set_timer1(0);
unsigned char s = 0;
unsigned char hb = 0;
unsigned char lb = 0;
unsigned long temp = 0;
for(s = 0; s < 8; s++)
temp <<= 2;
if((value & 0x80) != 0)
temp |= 0x1;
temp |= 0x2;
value <<= 1;
hb = ((temp & 0xFF00) >> 8);
lb = (temp & 0x00FF);
for(s = 0; s < 2; s++)
putc(0x00);
putc(0x55);
putc(hb);
putc(lb);
putc(hb & lb);
putc(0xAA);
delay_ms(40);
RX
| Code: | #include <16F630.h>
#device *= 16
#fuses NOMCLR, NOWDT, PROTECT, CPD, INTRC_IO, BROWNOUT
#use RS232 (xmit = pin_C5, rcv = pin_C4, baud = 1200, stop = 1, parity = N)
#define OUT1 pin_C0
#define OUT2 pin_C1
#define OUT3 pin_C2
#define OUT4 pin_C3
void setup();
unsigned char receive_data();
unsigned char value = 0;
setup();
value = receive_data();
if(value == 0x04)
output_toggle(OUT1);
if(value == 0x06)
output_toggle(OUT2);
if(value == 0x09)
output_toggle(OUT3);
if(value == 0x11)
output_toggle(OUT4);
void setup()
set_timer0(0);
set_timer1(0);
unsigned char cmd[4];
unsigned char tmp1 = 0;
unsigned char tmp2 = 0;
if(kbhit())
if(getc() == 0x55)
for(s = 0; s < 4; s++)
cmd[s] = getc();
tmp1 = cmd[0];
tmp2 = cmd[1];
if(((tmp2 & tmp1) == cmd[2]) && (cmd[3] == 0xAA))
temp = tmp1;
temp <<= 8;
temp |= tmp2;
tmp2 = 0;
tmp2 <<= 1;
if((temp & 0xC000) == 0x8000)
tmp2 |= 0x00;
else if((temp & 0xC000) == 0x4000)
tmp2 |= 0x01;
temp <<= 2;
return tmp2;
_________________ https://www.facebook.com/MicroArena
SShahryiar |
