PIC24FJ64GA308 internal pullup reads 2V
guy
PostPosted: Sun Sep 14, 2014 6:33 am     Reply with quote
Did anyone else notice this? Shouldn't it go up to VCC (3.3V) ?
I am testing with an oscilloscope which has 10M ohm resistor to GND so it's not because of the 'scope.
I noticed this on PORTE but didn't check other ports.
PostPosted: Sun Sep 14, 2014 7:44 am     Reply with quote
No.....
They are not resistors. They are transistor current sources. Read the data sheet. Section 11.3;
"When the internal pull-up is selected, the pin pulls up to
VDD – 1.1V (typical). When the internal pull-down is
selected, the pin pulls down to VSS."
The pull up is also _weak_. 290uA typically. I'd have probably expected more like 2.1v, but your figure is not unreasonable.
PostPosted: Sun Sep 14, 2014 7:48 am     Reply with quote
This is a Microchip question. Google for it. Example:
internal pullup reads 2V site:microchip.com/forums
http://www.microchip.com/forums/m755702.aspx
http://www.microchip.com/forums/m400027.aspx
http://www.microchip.com/forums/m692732.aspx
http://www.microchip.com/forums/m799735.aspx
If that doesn't help, sign-up for an account with Microchip support and
open a Trouble Ticket. Their techs will answer your questions if they can.
