Problem with 16f877a code writing for lcd interface
uma
PostPosted: Thu Apr 17, 2014 11:30 pm     Reply with quote
Error msg: cannot change device type this far into the code. (line2)
#include <pgm1.h>
#include <16F877A.h>
//#fuses XT,NOWDT
#include <lcd.c>
#define lcd_RD4     PIN_RD0
#define lcd_RD5     PIN_RD1
#define lcd_RD6     PIN_RD2
#define lcd_RD7     PIN_RD3
#define lcd_E       PIN_RB1
#define lcd_RS      PIN_RB2
set_tris_d(0x00);
set_tris_b(0x00);
output_d(0x00);
output_b(0x00);
delay_ms(1500);
//lcd_cursor_on(1,TRUE);
//for(;;)
    lcd_gotoxy(1,1);
    Printf(lcd_putc,"/f welcome to ETPL");
    lcd_gotoxy(1,2);
    Printf(lcd_putc,"/n LCD interface");
uma
Application Engineer,
ETPL
Mike Walne
PostPosted: Fri Apr 18, 2014 1:48 am     Reply with quote
The error message is telling you what to do.
Try putting
as the first line, rather than second.
Mike
uma
PostPosted: Fri Apr 18, 2014 3:13 am     Reply with quote
I tried that too as you said, and i have made little changes also,even then it is showing errr.
#include <16F877.h>
#include <pgm1.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#define lcd_DATA4             PIN_D0
#define lcd_DATA5             PIN_D1
#define lcd_DATA6             PIN_D2
#define lcd_DATA7             PIN_D3
#define lcd_ENABLE_PIN        PIN_B1
#define lcd_RS_PIN            PIN_B2
#include <lcd.c>
set_tris_d(0x00);
set_tris_b(0x00);
output_d(0x00);
output_b(0x00);
delay_ms(1500);
    printf(lcd_putc,"/f welcome to ETPL");
    lcd_gotoxy(1,2);
how to attach the error screen shot with this?
uma
ETPL
Mike Walne
PostPosted: Fri Apr 18, 2014 4:33 am     Reply with quote
You can copy and paste to show error messages.
What is the error you are now getting?
Your code is not complete and compilable.
I don't have your pgm1.h file
Therefore, I can't readily test your code on my system.
At this stage you are making me second guess what you have done.
If you want help, you need to make it easy for us.
Mike
uma
i have simplified the code and now no result in simulation.
PostPosted: Fri Apr 18, 2014 5:11 am     Reply with quote
#include<16f877a.h>
#define LCD_ENABLE_PIN PIN_C0
#define LCD_RS_PIN PIN_C1
#define LCD_RW_PIN PIN_C2
#define LCD_DATA4 PIN_D4
#define LCD_DATA5 PIN_D5
#define LCD_DATA6 PIN_D6
#define LCD_DATA7 PIN_D7
#include <lcd.c>
   set_tris_d(0x00);
   set_tris_c(0x00);
    Delay_ms(100);
      lcd_gotoxy(1,1);
      Delay_ms(1000);
      lcd_putc("\f Hello ETPL...\n");
Here is the link of screen shot of simulation:
http://www.2shared.com/photo/aQY7aQyF/proteus_disp.html
http://www.2shared.com/photo/tOFGqXrt/warning_msg.html
uma
ETPL
uma
solved,mstke is connection.
PostPosted: Fri Apr 18, 2014 5:53 am     Reply with quote
connected the D4,D5,D6,D7 PIN of MCU to D0,D1,D2,D3 is the problem.
Again i connected it to D4,D5,D6,D7 pin of LCD and grounded the upper nibble.
uma
ETPL
PostPosted: Fri Apr 18, 2014 5:54 am     Reply with quote
a clear message about what the problem is , can be found here :
http://www.ccsinfo.com/forum/viewtopic.php?t=47549
Mike Walne
PostPosted: Fri Apr 18, 2014 8:40 am     Reply with quote
I refuse to deal with Proteus/ISIS issues.
Come back when you are using real hardware.
This line deals with the pin connections
#include <lcd.c>
You therefore don't need these
You don't need these lines. The CCS compiler deals with I/O's
   set_tris_d(0x00);
   set_tris_c(0x00);
The list goes on ..........................
Your link to the screen shot was a waste of my time and effort.
Mike
PostPosted: Fri Apr 18, 2014 10:36 am     Reply with quote
to begin with... if you wired up the project according to your schematic..it'll never work !!!
1) no xtal or caps on PIC clk pins.
2) no power to PIC
3) not supposed to ground LCD data pins...
3 strikes and I'm out.
Happy to help but come back with real hardware.....
jay
PostPosted: Fri Apr 18, 2014 1:33 pm     Reply with quote
Connect your LCD according to this schematic:
http://2.bp.blogspot.com/-8xC4RgF8scM/TxlLYKaSFaI/AAAAAAAAACk/7FODBf0jvRo/s1600/Schematic.png
Compile and run this test program below, and it should work.
This program uses the CCS lcd.c driver, and it defaults to using PortD for
the lcd. The schematic in the link above uses PortD, exactly as required
by the CCS lcd.c driver.
#fuses XT, NOWDT, BROWNOUT, PUT, NOLVP
#use delay(clock=4M)
#include <lcd.c>
printf(lcd_putc, "\fHello World");
uma
RE: problem of lcd interface
PostPosted: Sat Apr 19, 2014 12:22 am     Reply with quote
Thanks for everyone who replied, sorry if anyone of you feel that i have wasted your time.
I am struggling because i am new to this field,so i am working from basic.
uma
ETPL
