uma
Problem with 16f877a code writing for lcd interface |
Posted: Thu Apr 17, 2014 11:30 pm |
Error msg: cannot change device type this far into the code. (line2)
#include <pgm1.h>
#include <16F877A.h>
//#fuses XT,NOWDT
#include <lcd.c>
#define lcd_RD4 PIN_RD0
#define lcd_RD5 PIN_RD1
#define lcd_RD6 PIN_RD2
#define lcd_RD7 PIN_RD3
#define lcd_E PIN_RB1
#define lcd_RS PIN_RB2
set_tris_d(0x00);
set_tris_b(0x00);
output_d(0x00);
output_b(0x00);
delay_ms(1500);
//lcd_cursor_on(1,TRUE);
//for(;;)
lcd_gotoxy(1,1);
Printf(lcd_putc,"/f welcome to ETPL");
lcd_gotoxy(1,2);
Printf(lcd_putc,"/n LCD interface");
_________________ uma
Application Engineer,
ETPL |
Mike Walne
Posted: Fri Apr 18, 2014 1:48 am |
The error message is telling you what to do.
Try putting
Code: | #include <16F877A.h> | as the first line, rather than second.
Mike |
uma
Posted: Fri Apr 18, 2014 3:13 am |
I tried that too as you said, and i have made little changes also,even then it is showing errr.
#include <16F877.h>
#include <pgm1.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#define lcd_DATA4 PIN_D0
#define lcd_DATA5 PIN_D1
#define lcd_DATA6 PIN_D2
#define lcd_DATA7 PIN_D3
#define lcd_ENABLE_PIN PIN_B1
#define lcd_RS_PIN PIN_B2
#include <lcd.c>
set_tris_d(0x00);
set_tris_b(0x00);
output_d(0x00);
output_b(0x00);
delay_ms(1500);
printf(lcd_putc,"/f welcome to ETPL");
lcd_gotoxy(1,2);
how to attach the error screen shot with this? _________________ uma
ETPL |
Mike Walne
Posted: Fri Apr 18, 2014 4:33 am |
You can copy and paste to show error messages.
What is the error you are now getting?
Your code is not complete and compilable.
I don't have your pgm1.h file
Therefore, I can't readily test your code on my system.
At this stage you are making me second guess what you have done.
If you want help, you need to make it easy for us.
Mike |
uma
i have simplified the code and now no result in simulation. |
Posted: Fri Apr 18, 2014 5:11 am |
Code: | #include<16f877a.h>
#define LCD_ENABLE_PIN PIN_C0
#define LCD_RS_PIN PIN_C1
#define LCD_RW_PIN PIN_C2
#define LCD_DATA4 PIN_D4
#define LCD_DATA5 PIN_D5
#define LCD_DATA6 PIN_D6
#define LCD_DATA7 PIN_D7
#include <lcd.c>
set_tris_d(0x00);
set_tris_c(0x00);
Delay_ms(100);
lcd_gotoxy(1,1);
Delay_ms(1000);
lcd_putc("\f Hello ETPL...\n");
Here is the link of screen shot of simulation:
http://www.2shared.com/photo/aQY7aQyF/proteus_disp.html
http://www.2shared.com/photo/tOFGqXrt/warning_msg.html _________________ uma
ETPL |
uma
solved,mstke is connection. |
Posted: Fri Apr 18, 2014 5:53 am |
connected the D4,D5,D6,D7 PIN of MCU to D0,D1,D2,D3 is the problem.
Again i connected it to D4,D5,D6,D7 pin of LCD and grounded the upper nibble. _________________ uma
ETPL |
Mike Walne
Posted: Fri Apr 18, 2014 8:40 am |
I refuse to deal with Proteus/ISIS issues.
Come back when you are using real hardware.
This line deals with the pin connections
You therefore don't need these
Code: | #define LCD_ENABLE_PIN PIN_C0
#define LCD_DATA7 PIN_D7 |
You don't need these lines. The CCS compiler deals with I/O's
Code: | set_tris_d(0x00);
set_tris_c(0x00); |
The list goes on ..........................
Your link to the screen shot was a waste of my time and effort.
Mike |
Joined: 01 Jul 2010 Posts: 9199 Location: Greensville,Ontario
Posted: Fri Apr 18, 2014 10:36 am |
to begin with... if you wired up the project according to your schematic..it'll never work !!!
1) no xtal or caps on PIC clk pins.
2) no power to PIC
3) not supposed to ground LCD data pins...
3 strikes and I'm out.
Happy to help but come back with real hardware.....
jay |
Posted: Fri Apr 18, 2014 1:33 pm |
Connect your LCD according to this schematic:
http://2.bp.blogspot.com/-8xC4RgF8scM/TxlLYKaSFaI/AAAAAAAAACk/7FODBf0jvRo/s1600/Schematic.png
Compile and run this test program below, and it should work.
This program uses the CCS lcd.c driver, and it defaults to using PortD for
the lcd. The schematic in the link above uses PortD, exactly as required
by the CCS lcd.c driver.
#fuses XT, NOWDT, BROWNOUT, PUT, NOLVP
#use delay(clock=4M)
#include <lcd.c>
printf(lcd_putc, "\fHello World");
uma
RE: problem of lcd interface |
Posted: Sat Apr 19, 2014 12:22 am |
Thanks for everyone who replied, sorry if anyone of you feel that i have wasted your time.
I am struggling because i am new to this field,so i am working from basic. _________________ uma
ETPL |
