paddy
Writing multiple registers function in modbus |
Posted: Fri Jan 11, 2013 4:34 am |
Hello All,
I am using modbus_slave.c example file in which i am using FUNC_WRITE_MULTIPLE_REGISTERS.
It works fine when i am writing data from starting address 0001. But when i change it with some another address, it will not work. I am not able to write data on other address except 0001.
Please have a look and suggest what i need to do.
case FUNC_WRITE_MULTIPLE_REGISTERS:
if(modbus_rx.data[0] || modbus_rx.data[2] ||
modbus_rx.data[1] >= 122 || modbus_rx.data[3]+modbus_rx.data[1] > 122)
modbus_exception_rsp(MODBUS_ADDRESS,modbus_rx.func,ILLEGAL_DATA_ADDRESS);
int i,j;
int8 k;
k=modbus_rx.data[1];
//for(i=0,j=5; i < modbus_rx.data[4]/2; ++i,j+=2)
for(i=k,j=5; i < modbus_rx.data[4]/2; ++i,j+=2)
hold_regs[i] = make16(modbus_rx.data[j+1],modbus_rx.data[j]);
modbus_write_multiple_registers_rsp(MODBUS_ADDRESS,
make16(modbus_rx.data[0],modbus_rx.data[1]),
make16(modbus_rx.data[2],modbus_rx.data[3]));
event_count++;
RF_Developer
Posted: Fri Jan 11, 2013 7:03 am |
There's a problem in your register writing loop:
As modbus_rx.data[4] is the count of data bytes in the message, i.e. twice the number of registers, you can't use it in that way as the end condition of the loop. Instead do:
hold_regs[k + i] = make16(modbus_rx.data[j+1],modbus_rx.data[j]);
This is limited to 128 registers and they mus all fall inside the 0-255 register address range.
In my implementation of this function I don't have all registers as "real" registers in the hold_regs array. For read, I have sixteen scratch, i.e. temporary, registers and send them to an virtualisation/abstraction routine that collects the data to the correct parts of my code. For write I simply send each register value in turn to my virtualisation routine.
// Data is big endian.
Write_Register(k + i, make16(modbus_rx.data[j],modbus_rx.data[j+1]));
This limits the number of registers that can be read in one message to the number of scratch registers.
RF Developer |
paddy
Posted: Sat Jan 12, 2013 4:34 am |
Yes!!! It worked!!!!
Thanks for your kind support. |
