Writing multiple registers function in modbus
paddy
PostPosted: Fri Jan 11, 2013 4:34 am     Reply with quote
Hello All,
I am using modbus_slave.c example file in which i am using FUNC_WRITE_MULTIPLE_REGISTERS.
It works fine when i am writing data from starting address 0001. But when i change it with some another address, it will not work. I am not able to write data on other address except 0001.
Please have a look and suggest what i need to do.
case FUNC_WRITE_MULTIPLE_REGISTERS:
                  if(modbus_rx.data[0] || modbus_rx.data[2] ||
                     modbus_rx.data[1] >= 122 || modbus_rx.data[3]+modbus_rx.data[1] > 122)
                     modbus_exception_rsp(MODBUS_ADDRESS,modbus_rx.func,ILLEGAL_DATA_ADDRESS);
                     int i,j;
                     int8 k;
                     k=modbus_rx.data[1];
                     //for(i=0,j=5; i < modbus_rx.data[4]/2; ++i,j+=2)
                     for(i=k,j=5; i < modbus_rx.data[4]/2; ++i,j+=2)
                        hold_regs[i] = make16(modbus_rx.data[j+1],modbus_rx.data[j]);
                     modbus_write_multiple_registers_rsp(MODBUS_ADDRESS,
                                    make16(modbus_rx.data[0],modbus_rx.data[1]),
                                    make16(modbus_rx.data[2],modbus_rx.data[3]));
                     event_count++;
RF_Developer
PostPosted: Fri Jan 11, 2013 7:03 am     Reply with quote
There's a problem in your register writing loop:
As modbus_rx.data[4] is the count of data bytes in the message, i.e. twice the number of registers, you can't use it in that way as the end condition of the loop. Instead do:
                        hold_regs[k + i] = make16(modbus_rx.data[j+1],modbus_rx.data[j]);
This is limited to 128 registers and they mus all fall inside the 0-255 register address range.
In my implementation of this function I don't have all registers as "real" registers in the hold_regs array. For read, I have sixteen scratch, i.e. temporary, registers and send them to an virtualisation/abstraction routine that collects the data to the correct parts of my code. For write I simply send each register value in turn to my virtualisation routine.
                  // Data is big endian.
                     Write_Register(k + i, make16(modbus_rx.data[j],modbus_rx.data[j+1]));
This limits the number of registers that can be read in one message to the number of scratch registers.
RF Developer
paddy
PostPosted: Sat Jan 12, 2013 4:34 am     Reply with quote
Yes!!! It worked!!!!
Thanks for your kind support.
