New ICD-U64 Problems with debug
Jeff_R
PostPosted: Fri Dec 31, 2010 9:37 am     Reply with quote
I recently purchased an ICD-U64 with the Canbus dev kit.
I have everything all set up and can program my target and it runs fine using the blink the green led first tutorial...
#include <18f4580.h>
#device ICD=TRUE
#fuses HS,NOLVP,NOWDT,NODEBUG,NOBROWNOUT
#use delay(clock=20000000)
#define GREEN_LED PIN_A5
      while (true)
      output_low(GREEN_LED);
      output_high(GREEN_LED);
When I try to run the debug I'm getting a condition where the led lights up and then nothing happens. So, I'm guessing the program has locked up.
I went through the ccsloader and did the diagnostic test and this is what I have.
Any ideas?
I searched for a couple hours reading everyone else troubles I tried everything previously mentioned.
Maybe the ICD-U64 is bad?
Jeff_R
PostPosted: Sat Jan 01, 2011 5:09 pm     Reply with quote
Just a follow up...the ICD-U64 seems to be nfg.
I hooked up my MachX which works great and plugged in the ICD cable to the bottom of the unit. (Never did this before as I never debugged live before.)
Everything worked fine, same programs same hardware.
So I was able to burn through a bunch of the tutorials today. I'll have to chat with CCS support on Monday about getting a new ICD.
Jeff_R
PostPosted: Sat Jan 08, 2011 7:45 pm     Reply with quote
Sent an email to CCS describing my problem, I'm very happy with their prompt response.
They initiated everything for me and sent me a new unit out via UPS overnight. They even sent me a return shipping label to send back the defect ICD-U64.
I received the new ICD-U64 unit and tested it...and everything is working wonderfully!
Thanks to CCS for taking good care of me through a small roadbump in my Canbus learning curve!
gpsmikey
PostPosted: Sat Jan 08, 2011 8:40 pm     Reply with quote
This canbus stuff is driving me nuts ... I keep reading it as "[spam]" and NO, I never touch the stuff Very Happy (really !! )
Glad to hear you got it resolved. I had considered buying one of those but was not sure about it with some of the issues others had mentioned here. I do have a couple of the PicKit2 gadgets that work well, but CCS IDE doesn't speak to them for debug as near as I have been able to find out. I am interested in the experiences others have had with them though.
mikey
[edit] oh sigh - the filters took it out - you know, the stuff with the funny leaves that people smoke Rolling Eyes
mikey
old engineering saying: 1+1 = 3 for sufficiently large values of 1 or small values of 3
