		| Author | Message |
		| Jeff_R
				| New ICD-U64 Problems with debug |
				|  Posted: Fri Dec 31, 2010 9:37 am |   |
				| Hello,
 I recently purchased an ICD-U64 with the Canbus dev kit.
 I have everything all set up and can program my target and it runs fine using the blink the green led first tutorial...
  	  | Code: |  	  | #include <18f4580.h> #device ICD=TRUE
 #fuses HS,NOLVP,NOWDT,NODEBUG,NOBROWNOUT
 #define GREEN_LED PIN_A5
 while (true)
 output_low(GREEN_LED);
 output_high(GREEN_LED);
 When I try to run the debug I'm getting a condition where the led lights up and then nothing happens. So, I'm guessing the program has locked up.
 I went through the ccsloader and did the diagnostic test and this is what I have.
 Any ideas?
 I searched for a couple hours reading everyone else troubles I tried everything previously mentioned.
 Maybe the ICD-U64 is bad?
		| Jeff_R
				|  Posted: Sat Jan 01, 2011 5:09 pm |   |
				| Just a follow up...the ICD-U64 seems to be nfg.
 I hooked up my MachX which works great and plugged in the ICD cable to the bottom of the unit. (Never did this before as I never debugged live before.)
 Everything worked fine, same programs same hardware.
 So I was able to burn through a bunch of the tutorials today. I'll have to chat with CCS support on Monday about getting a new ICD.
		| Jeff_R
				|  Posted: Sat Jan 08, 2011 7:45 pm |   |
				| Sent an email to CCS describing my problem, I'm very happy with their prompt response.
 They initiated everything for me and sent me a new unit out via UPS overnight. They even sent me a return shipping label to send back the defect ICD-U64.
 I received the new ICD-U64 unit and tested it...and everything is working wonderfully!
 Thanks to CCS for taking good care of me through a small roadbump in my Canbus learning curve!
		| gpsmikey
				|  Posted: Sat Jan 08, 2011 8:40 pm |   |
				| This canbus stuff is driving me nuts ... I keep reading it as "[spam]" and NO, I never touch the stuff  (really !! )
 Glad to hear you got it resolved.  I had considered buying one of those but was not sure about it with some of the issues others had mentioned here.  I do have a couple of the PicKit2 gadgets that work well, but CCS IDE doesn't speak to them for debug as near as I have been able to find out.  I am interested in the experiences others have had with them though.
 mikey
 [edit] oh sigh - the filters took it out - you know, the stuff with the funny leaves that people smoke
 mikey
