I'm using 12F509 in my design, and am able to program it using Microchip's ICD2 tool. Once programmed however, I can't seem to clear the memory or reprogram it.
This is a 3v design.
Thanks for any help you can give.
FvM
Posted: Thu Sep 25, 2008 6:13 am
You should read the specification in detail. Many devices need 4.5V minimum for erase/write. Devices, that can be programmed at 3V need higher voltage to remove protection by a chip erase.
PCram Guest
Re-programming 12F509 with ICD2
Posted: Fri Sep 26, 2008 1:22 pm
That was it. Bumped up to 4.5v and we're reprogramming just as expected.
