Re-programming 12F509 with ICD2
PCram
PostPosted: Thu Sep 25, 2008 5:52 am     Reply with quote
I'm using 12F509 in my design, and am able to program it using Microchip's ICD2 tool. Once programmed however, I can't seem to clear the memory or reprogram it.
This is a 3v design.
Thanks for any help you can give.
PostPosted: Thu Sep 25, 2008 6:13 am     Reply with quote
You should read the specification in detail. Many devices need 4.5V minimum for erase/write. Devices, that can be programmed at 3V need higher voltage to remove protection by a chip erase.
PCram
PostPosted: Fri Sep 26, 2008 1:22 pm     Reply with quote
That was it. Bumped up to 4.5v and we're reprogramming just as expected.
Thanks very much.
