RS485 Problem (rs485_get_message)
priesty100
PostPosted: Mon Mar 10, 2008 9:30 am     Reply with quote
I am having problems using the RS485 routines:
I am communicating with a servo driver which returns status information after every command it receives.
The section of code concerned is as follows:
         sprintf(rs485_tx_buffer,"%s\r",test_array);     //coppy the command from test_array to rs485_tx_buffer
         length = strlen(rs485_tx_buffer);               //count the number of characters in rs485_tx_buffer
         rs485_wait_for_bus(TRUE);                       //wait for RS485 Bus to become open
         rs485_send_message(1,length,rs485_tx_buffer);   //send message to servo control
         if(rs485_get_message(input_array, FALSE))       //read in message from rs485 into input_array
            for(i=0; i < input_array[1]; ++i)            //print contents of input array via RS232
               putc(input_array[i+2]);
        fprintf(PC,"\n\r");
The problem is that the rs485_get_message function always returns FALSE. If the wait input to the function is set as TRUE (to wait for a message), the program hangs.
Any thoughts or help would be most appreciated.
Thank you
Sam
treitmey
PostPosted: Tue Mar 11, 2008 8:25 am     Reply with quote
I don't get it.
is rs485_get_message() some sort of standardized function I should already
know about?
Why didn't you post that function?
PostPosted: Tue Mar 11, 2008 8:56 am     Reply with quote
He doesn't have to post it. It's in this file:
c:\Program Files\picc\Drivers\rs485.c
