ICD_U40 Prog LF
Storic
ICD_U40 Prog LF
PostPosted: Mon Mar 06, 2006 3:02 pm     Reply with quote
with the 18LF series micro (Low voltage 3.3v micro) I am not able to program the 18LF8621. is there a method in programming the LF micros or do we need to use the MPLAB ICD2 unit. Confused
the ICD2 connect and programs OK however I could not load the hex file into MPLAB to program (extension not recognised)? Sad
Any ideas
Andrew
What has been learnt if you make the same mistake? Wink
PostPosted: Mon Mar 06, 2006 4:23 pm     Reply with quote
However I could not load the hex file into MPLAB to program (extension not recognised)?
See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=26043
