Joined: 03 Dec 2005 Posts: 182 Location: Australia SA
ICD_U40 Prog LF
Posted: Mon Mar 06, 2006 3:02 pm
with the 18LF series micro (Low voltage 3.3v micro) I am not able to program the 18LF8621. is there a method in programming the LF micros or do we need to use the MPLAB ICD2 unit.
the ICD2 connect and programs OK however I could not load the hex file into MPLAB to program (extension not recognised)?
Any ideas
Andrew _________________ What has been learnt if you make the same mistake?
Posted: Mon Mar 06, 2006 4:23 pm
However I could not load the hex file into MPLAB to program (extension not recognised)?
