IC-Prog and 18F4550
Bart
IC-Prog and 18F4550
PostPosted: Wed Sep 28, 2005 4:29 pm     Reply with quote
As I can't find the 18F4550 in the list of supported devices for IC-Prog (http://www.ic-prog.com/devices.html) , I want to know if I can select a "compatible" type from that list for programming my 18F4550.
Thanks.
I like Skype (www.skype.com), my username is BplotM
treitmey
PostPosted: Thu Sep 29, 2005 8:05 am     Reply with quote
You could/should probably ask this in the main forum. If you have full compiler then pick a close uP and use the device editor.
kypec
Another application SW
PostPosted: Mon Oct 03, 2005 12:21 am     Reply with quote
I had a similar problem to yours (unsupported device in IC-Prog).
I tried WinPic800 instead and it helped me a lot.
Don't worry, you can use your JDM with WinPic800 just as I did.
Good luck,
kypec
kathirn
programmer
PostPosted: Sat Oct 22, 2005 8:35 pm     Reply with quote
i need jdm circuit diagram
Bart
PostPosted: Sun Oct 23, 2005 1:30 pm     Reply with quote
@ kathirn
Please register and log in, will see then how I can help you.
At my site, it's working fine now. WinPic800 is much beter than IC-Prog (just missing the checksum visualisation)
kathiresan
programmer
PostPosted: Sun Oct 23, 2005 7:28 pm     Reply with quote
i have registered my user name kathiresan
pl help me for jdm programmer
PostPosted: Mon Oct 24, 2005 12:02 pm     Reply with quote
Click on the following link. You will get over 600 hits for websites
with JDM programmer schematic.
http://www.google.com/search?hl=en&q=%22jdm+programmer%22+schematic&btnG=Google+Search
