Bart
IC-Prog and 18F4550 |
Posted: Wed Sep 28, 2005 4:29 pm |
As I can't find the 18F4550 in the list of supported devices for IC-Prog (http://www.ic-prog.com/devices.html) , I want to know if I can select a "compatible" type from that list for programming my 18F4550.
Thanks. _________________ I like Skype (www.skype.com), my username is BplotM |
treitmey
Posted: Thu Sep 29, 2005 8:05 am |
You could/should probably ask this in the main forum. If you have full compiler then pick a close uP and use the device editor. |
kypec
Another application SW |
Posted: Mon Oct 03, 2005 12:21 am |
I had a similar problem to yours (unsupported device in IC-Prog).
I tried WinPic800 instead and it helped me a lot.
Don't worry, you can use your JDM with WinPic800 just as I did.
Good luck,
kypec |
kathirn Guest
programmer |
Posted: Sat Oct 22, 2005 8:35 pm |
i need jdm circuit diagram |
Bart
Posted: Sun Oct 23, 2005 1:30 pm |
@ kathirn
Please register and log in, will see then how I can help you.
At my site, it's working fine now. WinPic800 is much beter than IC-Prog (just missing the checksum visualisation) _________________ I like Skype (www.skype.com), my username is BplotM |
kathiresan
programmer |
Posted: Sun Oct 23, 2005 7:28 pm |
i have registered my user name kathiresan
pl help me for jdm programmer |
